A white Scott Foil U-Di2
kampiakseli
by kampiakseli
Hi,
my Foil 30 L 56cm frame weigth was 1013gr. There was only rd hanger on.
Omiar
by Omiar
Joined with the chinese carbon wheels owners club. They are 60mm clinchers but still with reasonable weight 730g and 950g for front and rear respectively.
Stiffness seems to be ok too, dialed the brakes to 1mm from the rim and hammered them up to 55kmh on a flat. Didn't notice any brake rub.
Scott Foil Ultegra Di2
Scott Scale 35 26"
Scott Spark LTD 29" M8000
Omiar
by Omiar
I also managed to grab a Rotor 3D+ crank. Im going to install it with Rotor BB cups, will be interesting to see how so thin bearings hold up.
Anyway, what chainrings should I choose? I want something that shifts nice and is stiff. Stronglight seems to be rated highly in terms of shifting, but how stiff are the regular/chrono rings compared to DA7900 rings?
Scott Scale 35 26"
NGMN
by NGMN
Hold the phone, a mass produced 41/30 bearing, I didn't know it existed. As a Trek owner, my interest is piqued.
Anyways, 7900 rings seems to be amog the best, people seem to like Praxis very much.
Omiar
by Omiar
NGMN wrote:Hold the phone, a mass produced 41/30 bearing, I didn't know it existed. As a Trek owner, my interest is piqued.
7900 rings doesn't match the Rotor crank very well, but i'll give it a try once the crank arrives. I must admit though, that I haven't been able to remove the big ring from the DA crank. I tried once briefly - the out pin doesn't allow the chain ring to move enough.
Rotor makes the 30mm axle to 41mm diameter pressfit frame cups: Rotor PressFit 30 4130
http://www.rotoruk.co.uk/PressFit2.html
Scott Scale 35 26"
dellpan
by dellpan
Very very beautiful result!!! :D
Specialized Epic S-WORKS 29er
Pinarello Dogma 65.1 Think2
Omiar
by Omiar
This year started with Planet X cnc brakes, the Ultegras are going to my second bike. Should receive my Rotor BB cups today so I can install my 3D+ crank and q-rings.
Scott Scale 35 26"
oreoboreo
by oreoboreo
For a guy that has been without a road bike for a few years, it looks like you have been keeping in touch on what works well. You have done a great job on the Scott. A Foil is on my list also...
My name is Scott and I ride a Scott and approve this message!
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2015 Specialized SWorks Tarmac Da 9000
2016 Specialized SWorks Tarmac DA 9100
Omiar
by Omiar
I just installed Rotod 3D+ cranks today and as I didn't have any instruction with them, so had to figure out it myself.
1. I took the NDS crankarm and and turned the preload nut against the crankarm, so it wouldn't turn anymore.
2. I loosened the preload nut about 1/2 turns. A small gap opened between the preload nut and crankarm.
3. Installed the cranks.
4. Torqued the crankarm bolts to the spindle as recommended by Rotor.
5. The preload nut was too tight to turn it by hand. Using pliers I turned the preload nut in small increments back against the NDS crankarm until the crank were spinning freely.
I still can't use the two highest gears when being on the lower chainring on the front, the chain is rubbing againts the big chainring. I think I can space the DS crank more out with spacers, but that would give me only one gear back. One options would be to modify the preload nut by making it little thinner. But as I dont need those gears anyway, I will first see how the Rotor 4130 bearings will hold up.
Scott Scale 35 26"
Omiar
by Omiar
Scott Scale 35 26"
Allenbr
by Allenbr
I have precisely the same bike which I've been thinking about upgrading to Ultrgra di2,
Could you put up a few pics of your BB plug and the hole behind your head tube? I'd like to see how that worked out. (Any other pics - wire routing, grommets, etc would also be welcome).
I assume you were able to squeeze the internal junction block into the BB before reinstalling the plug?
Any other advice for this job?
Thanks,
Brandon
liam7020
by liam7020
Absolutely love these Scott Foils!
Belgian Flag S-Works Tarmac viewtopic.php?f=10&t=144553
Omiar
by Omiar
Allenbr wrote:I have precisely the same bike which I've been thinking about upgrading to Ultrgra di2,
Thanks,
Brandon
I'll try to make some.
Scott Scale 35 26"
Allenbr
by Allenbr
do you recall what wire lengths you used/needed?
(sorry, lots of q's)
B
Omiar
by Omiar
900mm, 650mm and 2pcs 400mm
You could get away with shorter ones, but it wasn't worth the potential extra hassle for me.
If you need anything else, a pm will yield in a quicker reply.
Scott Scale 35 26"
