Upgrading Syntace F99 stem's bolt to Ti, a good idea?
nrsnow
by nrsnow
Upgrading Syntace F99 stem's bolt to Ti. A good idea?
Ridley Excalibur
Scott Spark LTD 8.15kg (retired)
Giant NRS (Retired)
http://weightweenies.starbike.com/forum/viewtopic.php?f=1&t=104531
Martin.F
by Martin.F
I don't see why not. They are strong enough, no rust and save weight. Go for it :thumbup:
nrsnow
by nrsnow
The only one's i saw are the Ebay Asian versions. Is there anything else out there?
Ridley Excalibur
Giant NRS (Retired)
Martin.F
by Martin.F
http://www.torontocycles.com/ has a lot of high quality bolts :)
sstefanov
by sstefanov
Starbike sells the kit for what I think is a reasonable price too:
http://www.starbike.com/p/starbike.com-Titanium-bolt-kit-M5x14-mm-for-Syntace-F99-1510-en#6692
TheRookie
by TheRookie
The ebay asian stuff is 'OK' but the threads are not as well made as they should be....
thewatchtech
by thewatchtech
I did it a couple of seasons ago and have no problems. The only comment I can add is to make sure you get screws with rounded heads. I initially had stem mounting bolts with sharp edges and my knee would get cut up whenever it grazed the stem.
Varaxis
by Varaxis
The F109 comes with Ti bolts, so I would assume there isn't an issue from a durability stand point, considering how Syntace tests their products. They seem to be the same design, except for the different handlebar clamping diameter, and they even offer Ti bolts and as option for the F99. I did have issues with the F109 slipping on my steerer, on the other hand, and have since replaced the stem, so that may have been an issue with that could be at least partially attributed to the Ti bolts (yes, I own and use torque wrenchs on my bike).
Bradley
by Bradley
Have had Titainium bolts on my F99 75mm for the past 18 months and it has been sound touch wood (Touches wood).
sh33mon
by sh33mon
Don't think it would be a problem either.
02GF74
by 02GF74
TheRookie wrote:The ebay asian stuff is 'OK' but the threads are not as well made as they should be....
yes, the Chinese/Taiwanese bolts have cut threads which are not as strong as rolled threads but that should not be a worry - most bolts I've seen fail shear as opposed to the thread being stripped off (no doubt there will be lots of post saying otherwise!!). I am using Ti bolts but so far not yet on steerer the or bar clamp. (oh, and don;t even think of aluminium alloy for these!)
In UK try Tibolts (Superstar components) and Probolt.
nrsnow
by nrsnow
I bought some asian ti bolts. Do I have to use ti prep grease?
Ridley Excalibur
Giant NRS (Retired)
Bradley
by Bradley
nrsnow wrote:I bought some asian ti bolts. Do I have to use ti prep grease?
Ideally yes but I personally have always just made sure there was some type of grease on the threads.
I use finish line grease that has never been a problem with me.
Velofreak
by Velofreak
go for it, ti is no problem, alu is dangerous.
tompho
by tompho
I also use finish line grease.
