Powerprofiles
8min@335W - 5.5w/kg - 149bpm HR avg - 162bpm HR peak
Pleased with this (though it's pretty modest compared to some in this thread .) HR says I could have done more, but this was less than 24hr after 145min at 4.0w/kg and immediately following 2x5min at 105% of FT and 2min recovery.
Here goes mine:
5s: 1151w - 19.02 W/Kg
10s: 1093w - 18.06 W/Kg
20s: 920w - 15.2 W/Kg
30s: 866w - 14.31 W/kg
1m: 653w - 10.79 W/Kg
2m: 506w - 8.36 W/Kg
5m: 403w - 6.66 W/Kg
20m: 335 - 5.53 W/Kg
40m: 305w - 5.05 W/Kg
1h: 288w - 4.76 W/Kg. Never actually tested, this happened on a 90min hill climb, mass start race.
2h: 271w - 4.47 W/Kg. On Zwift. Ugh.
https://www.strava.com/athletes/2218901
Loving life in Málaga, Spain.
Can someone make a frequency plot so we can see the proportion of posters who have various different values of FTP? This thread always feels like 99% have an FTP over 5 W/kg. Failing that upper 4's.
My 3min power at the moment is the same as my best FTP W/kg. I wish I appreciated those better times more at the time!
TriJoeri wrote: ↑Tue Jul 07, 2020 9:57 amStill no competition so a bit heavier than I'm supposed to be. 5'7" (170cm) and 149lbs (67.2kg) at the moment. Olympic/Half distance triathlete but still reasonably punchy.
1": 1125W (16.77W/kg)
2": 1109W (16.53W/kg)
5": 1073W (15.99W/kg)
10": 987W (14.71W/kg. During a seated 20" effort for an INSCYD test)
20": 879W (13.1W/kg)
30": 728W (10.85W/kg)
1': 543W (8.09W/kg, during INSCYD 3' effort)
2': 476W (7.09W/kg, during INSCYD 3' effort)
5': 365W (5.44W/kg, during INSCYD 6' effort)
10': 332W (4.95W/kg, during INSCYD 12' effort))
20': 306W (4.61W/kg, during 44' Zwift TT at lower weight 66.4kg) Now 320W at 66.3kg (4.83W/kg), also in a Zwift TT
30': 299W (4.5W/kg, during 44' Zwift TT at lower weight 66.4kg)
40': 296W (4.46W/kg, during 44' Zwift TT at lower weight 66.4kg)
1h: 292W (4.4W/kg at 66.3kg) but this was in a Zwift road race so with some tactics involved and not an best power effort
10", 20" and 30" I should be able to improve on if I were to do them now.
People with weaker stats don't post... for example I just got into the 2W/kg range. Nobody wants to see thatDanW wrote: ↑Thu Nov 12, 2020 11:58 amCan someone make a frequency plot so we can see the proportion of posters who have various different values of FTP? This thread always feels like 99% have an FTP over 5 W/kg. Failing that upper 4's.
Just did the final FTP test of the year. Very pleased with the result.
379W for 20min -> 360W FTP @ 70.7kg -> almost 5.1 W/kg.
168bpm average and 175bpm peak (which is the highest heart rate I have reached all year).
For this being on an indoor trainer, I am quite pleased.
Also, 451W for 4:25 min (meant to do 4min max, but had under paced it) last week (outdoors), which is a PB for me.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
Seriously, all of these numbers make me feel inadequate. Here's mine from 2020 anyways (which has been the best year in terms of my cycling fitness):cheapvega wrote: ↑Fri Nov 13, 2020 4:45 amPeople with weaker stats don't post... for example I just got into the 2W/kg range. Nobody wants to see thatDanW wrote: ↑Thu Nov 12, 2020 11:58 amCan someone make a frequency plot so we can see the proportion of posters who have various different values of FTP? This thread always feels like 99% have an FTP over 5 W/kg. Failing that upper 4's.
Weight:63kg Height: 172cm
Time Watts/kg Watts
1s 12.39 768
15s 10.9 677
1m 5.88 388
5m 4.39 272
10m 3.89 241
20m 3.85 239
30m 3.81 236
1h 3.34 207
2h 2.92 180
I see you numbers and I will lower them!
These are at least 50W off my best numbers at 10-15kg heavier A long way off those times being of being much lighter with an FTP around 300W... but the journey starts again!
Weight: 85kg Height: 175cm
Time Watts/kg Watts
1s 10.5 896
15s 8.2 695
1m 5.3 453
5m 3.7 315
10m 3.2 273
20m 3.1 265
30m 2.7 232
Time Watts/kg Watts
1s 10.5 896
15s 8.2 695
1m 5.3 453
5m 3.7 315
10m 3.2 273
20m 3.1 265
30m 2.7 232
So, here's an update on my power curve on mostly a diet comprised of sub one hour zwift races on the weekdays (or worse, little to no activity during the weekdays as has been the case over the past month) and shorter weekend rides (although, that has flipped to roughly 6-8 hours on the weekend over the past month). Zwift has been my primary training for the large part of the pandemic.RyanH wrote: ↑Fri Oct 12, 2018 5:59 amNeed to get some maximal 30s and 1 min efforts as they should be much higher:
30s: 10.71w/kg (down from over 13)
1min: 9.28w/kg (down from over 10)
2.5 min: 6.97w/kg
5min: 6.01w/kg
7.5min: 5.82w/kg
10min: 5.46w/kg
20min: 5.00w/kg
I think I could stretch 8w/kg to a full 2 minutes. Currently at 1:40 but that was in the middle of a group ride and at the beginning of a 20 minute race portion.
Last 6 week power curve:
30s: 9.93 w/kg
1min:8.18w/kg
2.5 min: 6.4w/kg
5min: 5.7w/kg
10min: 5.2w/kg
20min: 4.8w/kg
60min: 4.3w/kg (new all time PR)
I've noticed that my ability to put out long efforts on the road is slightly less than on the trainer, which is strange to me. Attached are two efforts, one is a Zwift race where my RPE was like 8 and I felt good enough to shitpost during the ride (avg HR of 155) vs climbing Latigo with an RPE of 10 and avg HR of 172.
JeeeeezFlatlandClimber wrote:Just did the final FTP test of the year. Very pleased with the result.
I can't even hold 380w for 4mins let alone 20!
I've got a Sufferfest 4DP test scheduled for tomorrow. Hoping I've made some gains this year even though I've done sporadic riding/training at best.
Sent from my Pixel 5 using Tapatalk
Just go at your own pace and see what is possible. Winter is the best time to make those gains.Dannnnn wrote: ↑Mon Nov 30, 2020 8:44 pmJeeeeezFlatlandClimber wrote:Just did the final FTP test of the year. Very pleased with the result.
Last season really ended on a high in terms of power numbers, but I also noticed that I felt much better during races up to the 3h mark and repeated efforts in general. At "rund um Uzwil", a race on a rolling Parcours I managed to get up to 256w avg and 285NP, but also managed to snatch some points in the crits and most imprtantly finally found some confidence. Weight usually is somewhere between 60 and 62kg, maybe on the lower end of that towards the seasons ending.
After 4 weeks off the bike, the new season has just started Nov 1st and I have only done one proper test so far. Unfortunately I ran out of hill after 18 min, but the baseline is set around 300w/20min and therefore a 280ish FTP to begin the build up again. Endurance rides on the weekends and some running or riding on the rollers during the week until christmas.
Looking foward to 2021. The best is yet to come, eh?
- robbosmans
- Moderator
- Contact:
This is interesting thread so lets keep it going, I just completed my first ever training plan, an internet ftp build plan, pleased with the results. Raised my FTP from 211 to 258.
Weight: 61kg Height: 182cm
10min is probably higher, haven’t tested it in a while.
