Powerprofiles
A 60min all-out effort is strictly aerobic, so IMO it can reliably predict much longer intervals...there’s a reason why the average critical power curve is almost flat by the 10min mark. Going 4, 5, 6+ hours mostly relies on staving off many different types of fatigue and discomfort. I don’t condition for 100mi 10000ft events other than doing a couple rides of that profile in the weeks leading up to the event.
i bet the ability to do a good one hour test is predictive of the slope of the curve. i'd say "ftp" is a poor predictor for > 1 hour power insomuch as it is poorly estimated by protocols other than ride hard af for an hour.TobinHatesYou wrote: ↑Tue May 12, 2020 12:56 amA 60min all-out effort is strictly aerobic, so IMO it can reliably predict much longer intervals...there’s a reason why the average critical power curve is almost flat by the 10min mark. Going 4, 5, 6+ hours mostly relies on staving off many different types of fatigue and discomfort. I don’t condition for 100mi 10000ft events other than doing a couple rides of that profile in the weeks leading up to the event.
i think this leaves out is differences in efficiency. i'd guess that the slope beyond an hour will be different between similarly aerobically developed people because of differences in fat metabolism, glycogen storage, capacity for fueling, efficiency/sweat rate, etc. maybe not a huge variance across people but at least some. though i guess you can roll this into your definition of aerobic development so that there is no comparability too.
I'm going to assume optimum mid-ride nutrition / hydration because that is one thing that doesn't really require too much training. My fueling strategy for rides between 2.5-6 hours is basically the same... Hydration depends on the weather that day. Fat metabolism we can leave out considering I'm assuming taking between 1/2 to 2/3 of kcal burned in carbs. Just find foods and mix that won't cause GI distress, and you're good to go.zmjones wrote: ↑Tue May 12, 2020 6:41 am
Also I said critical power curve and not "FT" on purpose as to leave out any doubt that I meant actual 60min CP and not an estimated FTP. The main things slowing people down come down to other adaptations, not so much aerobic capacity / power.
Been indoors Zwifting for about 6 weeks now due to the covid situation. Stuck to a somewhat polarized "planless plan" that involved primarily zone 2 rides at 65% to 75% intensity and about 2 to 3 Zwift races of varying duration my hard days. I know this isn't ideal but I can't bring myself to commit to a proper structured workout plan as it simply kills the joy of riding.
Happy with the increase in threshold level power as it has always been my weakness. It also shows just how poor in quality my outside rides have been all these while. I do however feel that being able to stay home has also allowed me to sleep more (up to 10 hours a night as opposed to 5 or 6 hours) and that aided in the recovery process leading to better fitness gains.
183cm 85kg 32years old. Pretty shitty stats compared to what most of you are putting out at 15 to 20 kilos lighter.
Changes from 2nd April 2020 to 13th May 2020
1s 1770w 20.8w/kg
5s 1537w 18.1w/kg
10s 1398w 16.4w/kg
20s 1071w 12.6w/kg
30s 908w 10.7w/kg
1min 636w 7.5w/kg
2min 453w 5.3w/kg
5min 338w -> 386w 14.2% Improvement 4.5w/kg
10min 312w -> 334w 7.1% Improvement 3.9w/kg
20min 279w -> 313w 12.2% Improvement 3.7w/kg
30min 269w -> 302w 12.2% Improvement 3.55w/kg
57min36s 292w Best power recorded in a race short of an hour on zwift 3.44w/kg
1hr 241w never tested
2hr 206w never tested
1s 1770w 20.8w/kg
5s 1537w 18.1w/kg
10s 1398w 16.4w/kg
20s 1071w 12.6w/kg
30s 908w 10.7w/kg
1min 636w 7.5w/kg
2min 453w 5.3w/kg
I had a similar peak to you add could do 1,000w for around 40 seconds.
Just keeping pushing the pedals and your longer efforts will increase.
My peak is now only about 1,670w but 480 for 5 and 400 ish for 20.
Still detest any serious effort over an hour
IG: RhinosWorkshop
IG: RhinosWorkshop
So you have clearly not reached the ceiling. Massive improvements, you got a lot of room for more!leej88 wrote: ↑Tue May 12, 2020 5:56 pmBeen indoors Zwifting for about 6 weeks now due to the covid situation. Stuck to a somewhat polarized "planless plan" that involved primarily zone 2 rides at 65% to 75% intensity and about 2 to 3 Zwift races of varying duration my hard days. I know this isn't ideal but I can't bring myself to commit to a proper structured workout plan as it simply kills the joy of riding.
1s 1770w 20.8w/kg
5s 1537w 18.1w/kg
10s 1398w 16.4w/kg
20s 1071w 12.6w/kg
30s 908w 10.7w/kg
1min 636w 7.5w/kg
2min 453w 5.3w/kg
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
@ryanw
Those are very impressive numbers!
@FlatlandClimber
Thank you for kind words and I really do hope that that is the case.
This brief improvement has given me new hope as I was riding a lot outdoors prior to the covid19 pandemic but not seeing marked improvements in my power numbers.
I'm now a firm believer of quality over quantity and also how important a big a difference good quality sleep can make.
@FlatlandClimber
Update:FlatlandClimber wrote: ↑Sat Apr 04, 2020 12:21 amWow, so many great efforts!
Took up road cycling a year ago, and got pretty obsessed.
I am: 25 years of age, 190cm tall, and weigh 71kg.
My best efforts are:
5 seconds: 1102w
1 minute: 606w
4 minutes 10 seconds: 414 watts
20 minutes: 325 watts
45 minutes 11 seconds (my longest ever all out effort): 313 watts.
I think this is called "puncheur".
Weight down to 70kg
- 3 Minutes: 442 Watts
- 10 Minutes: 362 Watts
- 20 minutes: 351 Watts
- 41:30 Minutes (Alpe du Zwift): 339 Watts
Still no competition so a bit heavier than I'm supposed to be. 5'7" (170cm) and 149lbs (67.2kg) at the moment. Olympic/Half distance triathlete but still reasonably punchy.
1": 1125W (16.77W/kg)
2": 1109W (16.53W/kg)
5": 1073W (15.99W/kg)
10": 987W (14.71W/kg. During a seated 20" effort for an INSCYD test)
20": 879W (13.1W/kg)
30": 728W (10.85W/kg)
1': 543W (8.09W/kg, during INSCYD 3' effort)
2': 476W (7.09W/kg, during INSCYD 3' effort)
5': 365W (5.44W/kg, during INSCYD 6' effort)
10': 332W (4.95W/kg, during INSCYD 12' effort))
20': 306W (4.61W/kg, during 44' Zwift TT at lower weight 66.4kg)
30': 299W (4.5W/kg, during 44' Zwift TT at lower weight 66.4kg)
40': 296W (4.46W/kg, during 44' Zwift TT at lower weight 66.4kg)
No recent 1h long efforts. 10", 20" and 30" I should be able to improve on if I were to do them now.
After some improvements and changing from triathlon to only cycling, those are my results:
5s 12.2w/kg 842w
60s 6.62w/kg 457w
5m 4.87w/kg 336w
20m 4.45w/kg 307w
60m 3.44w/kg 238w
2h 3.24w/kg 224w
5h 2.20w/kg 152w
FTP 4.25w/kg 293w
I am not explosive, I know. I am only resilient
69Kg, 170cm, 38yr
5s 12.2w/kg 842w
60s 6.62w/kg 457w
5m 4.87w/kg 336w
20m 4.45w/kg 307w
60m 3.44w/kg 238w
2h 3.24w/kg 224w
5h 2.20w/kg 152w
FTP 4.25w/kg 293w
69Kg, 170cm, 38yr
My garage: Caad12, BRT C0, Cannondale Scalpel SE II, Specialized Epic pro '92, Swiss military bike '45, Orbea Gredos '87, Specialized Langster '12, Caadx '15...
Just recently done a 20 Min Test so I thought I'd throw my numbers up here. I'm down from circa 100kg, so still some way to go regarding my W/KG but pretty happy with the power numbers, particularly in the recent test. The longer 1/2 Hr numbers come from hilly races, so contain a mix of high power output on the climbs and a period of decending. By comparision, the 237w 2hr average, had a normalised power of 289w for the same ride.
Weight: 85.8kg / Height: 182cm
Time Power W/KG
1 s 1243 14.49
5 s 1185 13.81
10 s 1039 12.11
20 s 922 10.75
30 s 793 9.24
1 m 559 6.52
2 m 420 4.90
5 m 369 4.30
10 m 324 3.78
20 m 323 3.76
30 m 290 3.38
1 h 271 3.16
2 h 237 2.76
Time Power W/KG
1 s 1243 14.49
5 s 1185 13.81
10 s 1039 12.11
20 s 922 10.75
30 s 793 9.24
1 m 559 6.52
2 m 420 4.90
5 m 369 4.30
10 m 324 3.78
20 m 323 3.76
30 m 290 3.38
1 h 271 3.16
2 h 237 2.76
