body fat..
lite pete
by lite pete
I know that bodyfat scales are inaccurate so whats the best way to monitor it,
Also whats a healthy percentage for a 4/3 cat ?
rustychain
by rustychain
Should be in training forum but there is no one best body fat percentage. Biodiversity my friend, we are all different. We as cyclist all want to be 5% for performance but that is a sure recipe for getting sick for most of us and will often be offset by power reductions. Dropping body fat down for the TDF is one thing but don't think that's a healthy percentage year round. Read up on the health risks involved
Calipers are the easy and cheap way to measure with water immersion the gold standard
being honest with your mirror also works :beerchug:
WW Velocipedist Gargantuan
stella-azzurra
by stella-azzurra
With the inaccurate body fat scales you can take the average for 3 readings and then just note a change in the previous reading either up or down. So if you are at 20% now and in 4 months you are at 10% then you have definitely made improvements on shedding fat. The amount will alwways fluctuate based on the time of day you take the readings, when you hydrated, when you ate etc.
devinci
by devinci
Also, you will have a hard time calculating your body fat with caliper if you dont have someone experienced enought to measure it on you with the calipers.
Caliper method need practice before its accurate
BlackTiBob
by BlackTiBob
water immersion is the gold standard.
Health clubs seemed to charge an arm and a leg for that. I happened to get a referral to a guy who worked in phy ed dept at college and did testing on the side (in college pool) for way cheaper.
FYI, his % body fat figure for me was 25% less than Tanika (sp?) body fat scale. The Tanika would still track progress but not be nearly as accurate.
I should go back for treadmill VO2 max test but not sure what the exact value of that is????
Tapeworm
by Tapeworm
I think dexascan is the most accurate, can even give you a breakdown if bone and muscle density. Not sure where you could get one done or how much. I got one as part of a study at a uni.
"Physiology is all just propaganda and lies... all waiting to be disproven by the next study."
"I'm not a real doctor; But I am a real worm; I am an actual worm." - TMBG
stella-azzurra
by stella-azzurra
Body fat count or body mass index totally pointless for the non pro or even for the pro unless you are a body builder and doing contests. Most of us know we are fat by looking in the mirror. Even then there is not real value you can attach to a category of people. Why should cat 3/4 people need to have a fat percentage of X.
mattr
by mattr
lite pete wrote:I know that bodyfat scales are inaccurate so whats the best way to monitor it
erm, as a 3rd/4th cat, don't bother. If it wobbles in the mirror, you might want to get rid, other than that, ride your bike.
lite pete wrote:Also whats a healthy percentage for a 4/3 cat ?
as long as you aren't getting ill, its a healthy % body fat.
Tinea Pedis
by Tinea Pedis
I'd argue that BMI, unless used in population related data analysis, is altogether useless.
I think mattr hit the nail on the head though.
0nelove
by 0nelove
I agree with what other posters have said. It's very easy to see riders in the grand tours and think they are that skinny year around- then try to emulate it.
As someone who did exactly that as a young rider, I would strongly advise you to forget any/all notions of BF% as a useful measuring device. Again, as others have said, you'll end up sick, decreasing your performance substantially, and possibly with an eating disorder depending on how obsessive it becomes.
Skillgannon
by Skillgannon
Someone mentioned calipers - from memory, there was a study done about 5 years ago, which showed that even trained professionals don't get accurate and reliable results, and had a large spread of results, even with the same professional performing the test on the same person multiple times.
Calipers and impedence resistance measurements just aren't reliable results.
But what's the point in fussing over it? Don't worry about a healthy body fat percentage, especially if you aren't going ot be using a reliable method, just focus on keeping a healthy weight, and don't stress about the whole thing.
This board would be a nicer place if everyone would take themselves less seriously.
I almost miss Mr Search...
stella-azzurra
by stella-azzurra
It's a simple matter of calories in and calories out. The quality of calories, and type of exercise, your overall metabolism and genetics determine your optimal weight and fat percentages. A balance between good food, and good exercise will give you the best results.
mike12345
by mike12345
Hello Lite Pete,
There are some tools to monitor body fat accurately:
1. Skin Calipers
2. Bioelectrical Impedance
3. Hydrostatic Weighing
4. DEXA (Dual-Energy X-Ray Absorptiometry)
5. Air-Displacement Plethysmography
basilic
by basilic
Let's remember that the brain is mostly fat
mike131
by mike131
lite pete wrote:I know that bodyfat scales and balance board are inaccurate so whats the best way to monitor it,
Hi
Body-fat scales use a technology called bioelectrical impedance to estimate how much body fat you have.
It’s debatable whether you need to know your body fat in the first place. True, body weight can be deceptive because it doesn’t indicate how much is from fat and how much is from muscle. But there’s no widely accepted standard for ideal body fat
