trainer front axle stand
is there any stand out that with a fake hub that fork can tighten to so the front wheel is not needed, preferably height adjustable. Only see a tacx one but it's made for their roller so not the best fit.
I could make one using rack mount pieces but not sure if it's a good idea.
Kickr Climb but that's obviously an expensive solution
- MrCurrieinahurry
- Moderator
I looked at trying something similar but was concerned about the twisting forces with the front forks bolted in place
Basso Diamante super record EPS 12
BMC slr01 ultegra Di2
I was looking for a similar thing, mainly due to space, to allow me to get the bike closer to the desk.
In the end I turned my front wheel/fork to 90 degrees and a solid tyre. Note that my bike is permanently on the trainer, otherwise the 90 degree forks would be a pain to change everytime you moved the bike on/off the trainer.
A couple of options here for DIY, but I didn't trust myself
Way back in the '90s, the German Tour magazine had plans for a DIY workstand-front wheel mount was a wooden 4x4 sized post with a hole drilled for a spare 9mm front axle with locknuts and washers spaced to 100mm with a quick release.
Probably be pretty cheap to build something similar with the 4x4 post mounted to a melamine shelf board base.
