Hello I am currently riding a 13.5kg flat bar bike on bike paths and the road. Avg speed is 25km over 20km mostly flat.
I am new to cycling so fitness isn't there
My question is if i was on a road bike say 8kg would my avg speed by higher?
Regards
Heavy flat bar bike
Probably yes, but not primarily because of the weight.
Your speeds will increase if you can get in a more aggressive / lower body position because aerodynamic drag is the main force slowing you down.
Your speeds will also likely increase because road bikes typically have narrower tires with less rolling resistance.
