Because of COVID gyms are closed and I needed to somehow keep my legs in a certain level of fitness. So I use a compex muscle stimulator.
Firstly I bought it for the massage programs, tens and generally for pain relief.
But it has lot of work out programs too.
I mainly use it for my quads.
I do the program cross endurance and I have to tell you that it works quite well!
After a good session I feel the same as if I was lifting weights!
Do you use stimulators? What’s your take?
Muscle stimulators
The problem is you're not really targeting the specific muscle fibers used for activities. If I train exclusively on the bike, my quads will be set up for cycling...not running, not lifting boxes at home. Also I'd be doing nothing about the bone and soft tissues that need to be strengthened as well. Do you just not own any weights?
Muscle stimulation stuff, theraguns, recovery boots ... all mostly therapeutic.
Owning a big set of weight is a little too much for home with limited space.
Consider using resistance bands instead. A set is only around $60.
A few (3-5) rubber bands in the set will grant you near infinitely adjustable resistance. Want it tougher? Grab closer and stretch it more.
Example workouts:
Example workouts:
I have a Compex unit and use the strength, endurance and recovery modes quite regularly (usually while vegging out watching TV).
While I can't say EMS delivers on all it promises, I can say -- much like my rollers -- it's a enjoyable alternative that adds some diversity to my training.
