Kickr 18 flywheel making squeak noises
Aryeh
by Aryeh
Hi all,
Recently my 2018 Wahoo Kickr's flywheel started making squeak noises when pedaling at low speeds and I was wondering if anyone is familiar with this issue, and if anyone knows how to resolve it.
I've found quite a few videos showing the same issue, but non had advice on how to fix it.
https://youtu.be/SAwDpVlJcFU
Lucendi
by Lucendi
You want to change the two bearings on the flywheel axle;
My bearings on my -18 Kickr wore out or got damaged races after about 10 000 kms. But there was no visual sign or play in the bearing.
SKF is the best quality beaings there are and I recommend getting these;
https://www.ebay.co.uk/itm/174567458781 ... 4567458781
BEARING CLEARANCE: NORMAL-CN
BEARING TYPE: 2RS
BEARING PART NUMBER: 6003
ryanw
by ryanw
NTN are better than SKF, use higher manufacturing tollerances ;)
IG: RhinosWorkshop
Lucendi
by Lucendi
ryanw wrote:
Wed Jan 06, 2021 11:04 am
Swedish steel > Japanese steel :D
Aryeh
by Aryeh
I opened it up, and I noticed that the pully bolt oscillates when the flywheel is spinning. Is that normal? https://youtu.be/4T5ykAWxEGc
Also, there seems to be quite a bit of black belt dust in there.
Wahoo offered me a refurbished replacement of the same model for $250, but ordered bearings and I'm gonna see if that fixes it.
Lucendi
by Lucendi
Aryeh wrote:
Fri Jan 08, 2021 6:21 am
Some belt residue is normal, just scrape it off carefully not to damage the soft aluminium pulley wheel.
The video shows no oscillation or imbalance of the pulley wheel so it is also completely normal.
Aryeh
by Aryeh
I can't seem to get this bearing off of the flywheel. Anyone have any ideas? Image
Lucendi
by Lucendi
Aryeh wrote:
Tue Jan 12, 2021 3:37 pm
That is a good thing, It means the axle diameter and the bearing inner diameter are pretty damn close.
I used a small-ish bearing puller and pried it out;
Be careful not to damage the white and black sticker, it is how the kickr reads the RPM.
Lucendi
by Lucendi
Any update?
Did you get the Kickr fixed?
Aryeh
by Aryeh
Lucendi wrote:Any update?
I fixed the squeak sound but a new noise started so I ended up just opting for the replacement option from Wahoo for $250.
mcfarton
by mcfarton
That’s a good deal. The few times I have dealt with them the customer service has been great.
Lucendi
by Lucendi
Aryeh wrote:
Mon Feb 01, 2021 4:29 pm
Wahoo machining tolerances aren't up to a very high standard so replacement parts (that are up to a high standard) sometimes don't fit right. :/
