Favero assomia q-factor
Hi
I am more and more convenience that I will order Favero Assomia Due next week when they will be back on stock.
Only two things that I would like to know and for which I have toughts are this:
- q-factor, will there be any other fealing comapring to look Keo which a have now? Will leg be positioned more oudside and this can cause some pain/knee issue? Is there any other fealing?
- comparing to look is the feeling the same or are they smaller?
thank you
miha
thank you
miha
Favero claims they are 54mm. DC Rainmaker measured them at 55mm. Regular Shimano R9100 pedals are 51mm, wide are 55mm. Look KeO 2 Max and Blade = 53mm.
I regularly swap between look keo blades and Favero Assioma and don't notice any difertence in comfort or q-factor.
No complaints with the Assiomas, they have been flawless.
