HRM records HR when I'm not wearing it!
onemanpeloton
by onemanpeloton
This might be a stupid question, I'm not sure.
Yesterday I didn't wear my HRM and, instead, put it in my rucksack. To my surprise I saw HR readings on my wahoo bolt. When I got home I had an average of 55bpm and a max of 109.
This causes me to question all the readings I've collected from this HRM. Should I be concerned?
2017 Giant TCR Disc
2015 Giant TCX
2016 Cube Stereo 140
3Pio
by 3Pio
Dont worry.Just seem ur rouksac have a heart....Just care about it, and everything will be fine :)
Sent from my Mi A2 using Tapatalk
PokojniToza
by PokojniToza
Until several months ago there used to be a bike shop in the buildig where I am living. I would come back from a ride and if I do not turn off the Garmin (520) it would start to detect movement (I presume from other people with garmin sensors on their bikes, althouh I am not sure how, since they are not paired with my device???). Also, guitar pickups would pickup the signal from a HR strap:)
Calnago
by Calnago
It has become one with your soul. You have arrived. Embrace it. Ohhhmmmmm....
AJS914
by AJS914
HR doping!
onemanpeloton
by onemanpeloton
errr.....thanks guys :lol:
2017 Giant TCR Disc
2015 Giant TCX
mattr
by mattr
Was it touching or wrapped up in anything remotely conductive?
Mine gets "odd" behaviour if i leave it wrapped up in a towel or something, or leave it in a pocket with keys etc.
ms6073
by ms6073
onemanpeloton wrote:
Thu Mar 21, 2019 3:13 pm
Are you using an older analog/non-coded (i.e. not ANT+ or BlueTooth) HR transmitter? If you are using an analog/non-coded HR transmitter, then your Wahoo will not be able to discriminate between you or anyone else in your vicinity with an analog/non-coded HR transmitter.
onemanpeloton
by onemanpeloton
The HRM was in a pocket in my bag with just a few other things, keys, wallet, phone.
Its a wahoo tickr so it's a new hrm with bluetooth and ant+
I emailed wahoo and they said theyve never experienced this before. I've been advised to do a reset, which I've done, and now I'm going to see if I can replicate the problem.
The issue itself doesn't bother me, as long as it isn't influencing my HR readings when I'm wearing it
2017 Giant TCR Disc
2015 Giant TCX
mattr
by mattr
Mon Mar 25, 2019 10:02 am
Could have been shorting it out then.
onemanpeloton
by onemanpeloton
Yeah thats a good suggestion. It gave some fairly realistic numbers though which makes it all the weirder!
Will try and replicate this week and see what's going on
2017 Giant TCR Disc
2015 Giant TCX
sqber
by sqber
You put what where? HRM is Heart Rate Monitor but it seems you mean just the strap with sensor by saying HRM? So you did put the strap and sensor into your bag and kept the Wahoo Bolt running? Or how did you record the heart rate during the time of coming home? If so, there may have been something conductive fooling the heart rate strap/sensor to believe it is an electric field created by your heart. But in that case the heart rate line should be quite hectic with some zero values inbetween.
onemanpeloton
by onemanpeloton
sqber wrote:
Tue Apr 09, 2019 12:46 pm
I don't understand the confusion between HRM and "strap with sensor". Everything that I would normally wear on my body was in my bag.
I don't think anything was shorting it out, it gave far too much of a consistent and realistic reading for that to be likely
2017 Giant TCR Disc
2015 Giant TCX
