How to raise cadence effectively?
JBeauBikes2
by JBeauBikes2
One of my goals for the next 15 weeks is to be able to spin comfortably around 120-140 RPM.
I’m riding in a race called Little 500, they made a movie called Breaking Away based off of this. Anyways, every team races on the same 46x18 single-speed coaster-brake bike.The race usually goes about 24-25 MPH off the front, and that’s about 125 RPM with our gearing.
I can spin now around 105-110 pretty smoothly but start bouncing after that. Does anybody have any drills or ways of training to get your cadence up higher without bouncing? Also I have rollers and a Kickr if that impacts your response.
numberSix
by numberSix
In short, 10 minutes stints of target cadence, at moderate intensity. And of course build up to it, target should increase incrementally.
IMO rollers will highlight any hitch in the pedal stroke, especially if they're free-motion rollers. A saddle height that feels 'right' might actually cause a deceleration, while 5mm lower is a smoother circle.
peted76
by peted76
Yes, as numberSix says rollers, rollers and more rollers. Everything you need right there.
boots2000
by boots2000
Start with shorter blocks at 130-140 rpm.
Keep resistance way down at 1st- like not even feeling the chain.
Start with 5x30 sec- push it out to 5x2 min.
Then progress to efforts with shorter duration but higher tension/power.
AJS914
by AJS914
I do a couple drills:
10 sec 90rpm, 10 sec 100, 10 sec 110, 10 sec 120, 10 sec 130, 10 sec 140, ...
1 min 100rpm, 1 min 110, 1 min 120, 1 min 130, ...
Go as high as you can go without losing form.
I have to increase resistance on the trainer a bit as rpms increase because I can't do 140 at say 100 watts.
JBeauBikes2
by JBeauBikes2
AJS914 wrote:
Mon Jan 08, 2018 6:43 pm
When you say without losing form, do you mean without bouncing? I assume when you push cadence up, you’re saying you move it up from the bottom and slowly increase instead of pedaling at 120 rpm until you stop bouncing correct?
TonyM
by TonyM
You may also want to tweak your saddle height (also depending on your position on your bike) in order to achieve these 120-140 rpm with less bouncing.
JBeauBikes2
by JBeauBikes2
TonyM wrote:
Mon Jan 08, 2018 9:14 pm
I have a roller session planned for tonight, I’m going to tweak the saddle height 5, 7.5, and 10mm loser and see what kind of smoothness I can get.
AJS914
by AJS914
JBeauBikes2 wrote:
Mon Jan 08, 2018 8:41 pm
Correct!
FilmAt11
by FilmAt11
Isn't saddle height set as a compromise for the team for this race - not your individual height?
topflightpro
by topflightpro
One work out I often do is 10 seconds fast, 10 seconds faster, 10 seconds fastest. In those last 10 seconds, try to spin as fast as you possibly can.
As far as bouncing goes, keeping your core tight can also reduce bouncing. And work on pulling up on the pedal and not just pushing down. If your right leg is pulling up as your left is pushing down, you tend to balance out a bit, reducing the bouncing. You'll be riding a fixed gear bike in that race, and the up-stroke is more relevant/important.
JBeauBikes2
by JBeauBikes2
FilmAt11 wrote:
Tue Jan 09, 2018 1:48 am
Yes it is. As it works out for my team, one shorter guy will have his own bike and I’ll share a bike with 2 others. I’m in the middle of the other two guys height wise and the height discrepancies is only a 1.5 inch difference, so I think the bike will end up fitting me best.
We also build us bikes for Spring Series events like ITT’s, Miss-N-Out (basically Last man standing where the last across the line is eliminated every lap), and then Team Pursuit so I’ll have my own bike for all 3 of those.
jfranci3
by jfranci3
I've noticed cadence really depends on what I've been doing. When I'm off the bike and running on the treadmill, I can do 125+ easy.
Mr.Gib
by Mr.Gib
Easiest way is to use short cranks. Some riders can adapt immediately, others may take a bit of training to adjust. You can really get your feet flying with 170 mm or 160 mm cranks.
