Elite "My E Training" app - no power, but only on "level mode". Anyone else?
Rudi
by Rudi
Just got a new smart trainer (from Elite). I've downloaded their app (iOS phone and tablet) and used the year free subscription that came in the box. Got everything set up correctly I believe, I have no external power, cadence or speed sensors so am relying on the trainer for all of that. Using Bluetooth.
In the app, I have the same device as the CSC sensor, cadence sensor and power sensor (not sure what the CSC sensor is).
The weird bit
Using "power mode", I see speed, power and cadence
Using "program mode", I see speed, power and cadence
Using "level mode", it doesn't show me power.
Is that right?
It is obviously getting the power for the other two, but I was expecting "level mode" to be the harder you pedal, the more watts it shows.
Cervelo R3 - 5.4kg viewtopic.php?f=10&t=142420
jfranci3
by jfranci3
First of all, don't use their software it's horrible.
Second Bluetooth and ANT+ are made for single pairing, so you can only use receiver at a time. You may also need an USB extension cord because the range is only about 3'.
Third - I'd download the Zwift IOS app and test with that.
My Elite trainer came out of the box mis-calibrated for speed-cadence. I could never get it to where it needed to be. Good Luck!
