Wahoo Kickr and 12 x 135mm thru-axle - possible?
phunky
by phunky
This spring I finally got a new bike to give some company to my two Spectrums - a Bianchi Infinito, which has a 12 x 135mm thru-axle in the rear.
Can I buy an adapter to use my Kickr with the new bike? What I've found suggests no, but that seems silly to me.
Has anyone had any luck with getting a 12 x 135mm thru-axle to mate with the Kickr?
Thanks very much
motorthings
by motorthings
(original post removed) nevermind...i see now what you are saying
can you get a machine shop to modify a 12x142 kit to work?
without seeing the mismatch, i'm not sure what needs to be modified
motorthings
by motorthings
actually look at the comments here and you'll see another person (cafzg) who used the kit on a 12x135 setup
https://www.wahoofitness.com/devices/ac ... ke-adapter
phunky
by phunky
motorthings wrote:actually look at the comments here and you'll see another person (cafzg) who used the kit on a 12x135 setup
Thanks very much - I'll give that a whirl!
