Using the Kickr 3 (2017 model) with a campagnolo 9 speed bike?
Greatwhite7
by Greatwhite7
Can it be done somehow?
Wahoo said it could not technically be done but people had come up with their own way around the problem.
TIA.
glepore
by glepore
Wheels mfg made spacers to respace shimano cassettes to work with Campy. I don't think they were exactly Campy spacing, more or less designed to split the difference because they obviously were on only the non carrier cogs, but it worked fine. Still have some on an ancient set of zipp 440's on a custom bike circa 2004 or so. Probably someone on one of the forums (paceline?) might have a set. I have a bag full of ti cogs and spacers from that era but not sure what is what now unless someone can give me the dimension.
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.8) ; Anvil Custom steel Etap;1996 Colnago Technos Record
Greatwhite7
by Greatwhite7
glepore wrote:Wheels mfg made spacers to respace shimano cassettes to work with Campy. I don't think they were exactly Campy spacing, more or less designed to split the difference because they obviously were on only the non carrier cogs, but it worked fine. Still have some on an ancient set of zipp 440's on a custom bike circa 2004 or so. Probably someone on one of the forums (paceline?) might have a set. I have a bag full of ti cogs and spacers from that era but not sure what is what now unless someone can give me the dimension.
I can buy spacers.
So it should be possible with the spacers?
Do you put them on first or after the cassette?
bikerjulio
by bikerjulio
Wheels don't list them any more. There's the other thread here discussing the use of 10-speed Campy on this trainer, which has no easy solution, so you can imagine that 9-speed is even more obsolete.
All is not lost. Just plonk a Shimano 9-speed road cassette on there and you probably won't notice a problem.
There's sometimes a buggy.
One.
glepore
by glepore
Yes, wheels has discontinued them. You'd have to find them in the secondary market. And bikerjulio is correct-use a 9 spd shimano cassette, it'll shift "okay" and you'll likely be fine. There is some stuff on the web about how to move the cable to the other side of the bolt etc. https://www.sheldonbrown.com/drivetrain-mixing.shtml
Greatwhite7
by Greatwhite7
bikerjulio wrote:All is not lost. Just plonk a Shimano 9-speed road cassette on there and you probably won't notice a problem.
Thanks for that, but I might just go for the Kickr Snap instead then.
At least I know it will be 100% compatible.
