Maintaining fitness over 4 months with little riding
thencameyou
by thencameyou
Hi all,
I'm coming up to (hopefully) my last ever set of exams (in August/September). I'm a keen rider/racer with an emphasis on TT at present but will be doing a bit more road racing too. I will have likely 5-6 hours / week to ride over this time (possibly less), the riding is important for sanity preservation but I'd also like to maintain my form as much as possible (it'll be winter/spring here). Currently FTP of 300 (4.4w/kg) and 5 min power 395 - did both of those on the weekend so think they are an accurate reflection of reality...
Be grateful for any advice on how I should approach this.
Shrike
by Shrike
Was looking this up recently too, need to do the same over a three week trip. Seems that working at intensity is key as you lose fitness from the top down. So threshold blocks and VO2 intervals. Scrap anything endurance based. Wouldn't bother working any lower than sweetspot.
TheKaiser
by TheKaiser
Shrike wrote:Seems that working at intensity is key as you lose fitness from the top down. So threshold blocks and VO2 intervals. Scrap anything endurance based. Wouldn't bother working any lower than sweetspot.
Yes, my understanding from Joe Friel and other endurance focused coaches is that you can maintain fitness for an extended period at a 50% reduced volume, as long as you maintain the amount of high intensity work you are doing. If I recall correctly, that was based on some research that looked at a time period under 3 months, but it didn't indicate a tail off after that. It was just a limitation of how much time they had to run the study. One would have to assume that at some point your endurance for longer rides would begin to suffer, but I haven't seen any data establishing how far out that would begin. For a TT rider, endurance at the 2+ hr mark shouldn't really matter anyway.
MattSoutherden
by MattSoutherden
Turbo.
It may not be exciting, but you can make a significantly higher percentage of your time count on the turbo than you can on the open road.
Snacking on carrot sticks - Where did it all go so wrong?
Finsbury Park CC
thencameyou
by thencameyou
thencameyou wrote:Hi all,
the riding is important for sanity preservation but I'd also like to maintain my form as much as possible (it'll be winter/spring here). C\
see bold above. but i know the turbo is best. i find 2x20's nearly intolerable on the trainer even at 95% percent of what i can do outside so may have to resort to the sufferfest again
fromtrektocolnago
by fromtrektocolnago
If you have limited time to bike you should try running.Its important to maintain cardiovascular fitness and running will certainly do that
Colnago C-59 (Dura Ace)
Firefly(Ultegra)
Trek 5200(ultegra)
MattSoutherden
by MattSoutherden
You don't have to do all the time on the turbo. Maybe do a couple of hours on on the road one day a week when the weather is nice, and put the rest of the time on the turbo.
If you can set it up in the corner, you may also find that you get more time 'riding' than you would out on the road as you can just stick some shorts on and go. Then just jump in the shower after and get on with what you were doing. No need to clean the bike after rainy winter rides. No need to hand up lots of dripping kit. etc
Finsbury Park CC
KWalker
by KWalker
The best thing you can do is try to be as active as possible with any and every activity and stop worrying about it. Enjoy the challenge of being less fit.
Gramz
Failed Custom Bike
AJS914
by AJS914
thencameyou wrote:You see bold above. but i know the turbo is best. i find 2x20's nearly intolerable on the trainer even at 95% percent of what i can do outside so may have to resort to the sufferfest again
Try 80-90% to see if it's more tolerable. Or, break it up by doing 5 minute intervals with a 1 minute rest. Breaking it up really makes the time go by much faster for me.
