Elite Arion Mag rollers vs Sportscrafters OverDrive Pro
pmdd72
by pmdd72
Anyone have comparative experience between these two?
Based on their power curves I think either would be fine for me for threshold workouts, so I'm looking at other things like construction quality, smoothness, portability, durability, etc.
Opinions?
Juanmoretime
Administrator
by Juanmoretime
It might be hard to find someone that has tried both. I use a set of Sportcrafters rollers that are probably about 10 years old. I'm still on the original belt and the bearings still are spinning smooth as can be.
RESIDENT GRUMPY OLD MAN.
sanrensho
by sanrensho
The power curves on those two rollers are quite different. If it matters to you, the Sportscrafters rollers have a progressive resistance curve.
Sent from my MotoG3 using Tapatalk
ultyguy
by ultyguy
I had Elite Arion Mag and then upgraded to Digital for more resistance. I'd love to use a metal roller with high resistance though. Achilles heel of the Elite is the plastic rollers which can vibrate a bit.
whydobearsxplod
by whydobearsxplod
I own a set of sportcrafters overdrive with high inertia drum. I used them exclusively for all indoor training for 2 years. They handle threshold and even vo2 intervals very well.
I haven't tried elite rollers, but own a real turbo muin which seems to be very well built.
What I can say in comparison is that elite and sportcrafters customer service are night and day. Sportcrafters are passionate about making good products and stand by them.
Rick
by Rick
Where does the extra resistance come from on the Sportcrafters Overdrive Pro ? Is it magnetic, hydraulic, etc ?
sanrensho
by sanrensho
^^^Magnetic resistance. It's explained here:
https://sportcrafters.com/technology
erik$
by erik$
How do the overdrives handle low cadence work, sanrensho? Is +-50 okay? Ambiguous questions, I know, but some user experience would be great :)
sanrensho
by sanrensho
^^^Hopefully whydobearsxplod can answer.
I don't own the Overdrive rollers (I wish I did). I have the Planet X Resist, which are made by Sportcrafters and use magnetic linear resistance.
mtalebi
by mtalebi
whydobearsxplod wrote:
Tue Dec 15, 2015 1:42 pm
Hi there, I'm considering to buy the same exact set-up (sportcrafters overdrive with high inertia drum). While certain about the quality of the rollers themselves, not quite sure how much difference the high inertia drum is going to make in my overal experience? what kind of coasting time you can get with this set-up? TruTrainer for example claims like 30 s coasting down time when stop peddaling @ 40 mph, but unfortunately it's not in the budget right now. And finally which drum you'd pick if having only one choice: high inertia or progressive resistance? Would appreciate if you can give me some insight.
