True Weight Weenieism...
News, announcements and discussions about Weight Weenies. (members, please do not start topics in here.)
tabl10s
by tabl10s
starts at what poundage?
2015 Pinarello F8: 13.05lbs/5.915kg
2016 Rca: 11.07lbs/5.048kg
2018 Rca
2018 S-Works SL6 Ultralight: 12.03lbs
DamonRinard
by DamonRinard
...less than before!
Damon Rinard
Engineering Manager, Road Bikes
Cycling Sports Group, Cannondale
Ex-Kestrel, ex-Velomax, ex-Trek, ex-Cervelo
DamonRinard
by DamonRinard
"It's not so much where you are, as where you're headed."
-anonymous
Damon Rinard
Marin
by Marin
It used to be 5kg, but with disc and aero it's more like sub-7 is truly awesome now :P
donald
by donald
My 3.2 kg bike has an aero stem, fork, saddle and wheels. One can have aero and light weight.
tabl10s
by tabl10s
2018 Rca
dgasmd
by dgasmd
Marin wrote:It used to be 5kg, but with disc and aero it's more like sub-7 is truly awesome now :P
That’s not an understatement!! All 3 of my bikes are under 14.0 lb (6.36 kg), but I’ve always thought of WW bike’s under 13 lb!!
themidge
by themidge
IMO it isn't about the weight, it's how you go about achieving whatever weight you end up with. It could be a 4kg tuned-to-the-last special, or a touring tandem that is as light as possible using the same ideas as the 4kg road bike, but still only makes it down to 14kg or whatever because of durability and reliability etc. I wouldn't call something where someone's just thrown 20 grand at it and ended up with a superlight, but completely 'stock' build a true WW build.
ms6073
by ms6073
DamonRinard wrote:
Sun Dec 31, 2017 1:16 pm
-anonymous
Alternately:
"No matter where you go, there you are."
Buckaroo Banzai
knakkie
by knakkie
A true weightweenie never stops shedding weight of the bike/parts
Thomson
by Thomson
A weight saving is a weight saving right?
I think it's when even the small gains feel like a big gain.
LouisN
by LouisN
themidge wrote:
Tue Sep 18, 2018 6:59 pm
:up: Amen.
Louis :)
tabl10s
by tabl10s
Can't be stock with money thrown at it.
2018 Rca
themidge
by themidge
tabl10s wrote:
Sun Dec 01, 2019 3:15 pm
It can if you threw money at it in the first place :wink:
But really what I meant by 'stock' is 'not modified in any way'. I think a true WW bike has parts that have been modified to make them lighter and/or better. It gets a bit subjective around the 'choice parts' area, but in general I think it takes actual modification or choosing every part specially to be a true WW bike.
For example:
^ true WW
^ not true WW
FWIW, of all my bikes I consider only my Cannondale to be a WW bike, and even then it's somewhere in the grey area between 'true WW' and 'built up a frame with parts of my choice'
Nikoras
by Nikoras
If you're looking at a threshold 6.8kg seems like as good a place as any. Passing it means you've temporarily closed the door on any UCI races in favor of weenieing
