Road Disc groupset, Compact PM & Carbon road bars
MichaelB
by MichaelB
Hiya all,
Am slowly gathering bits to build up the replacement disc roadie frame (transferred most of the running gear to my Kenisis frame to keep me riding), so here are some bits that I'd like to get.
Note : I am located in Australia, so need to be abkle to ship there at reasonable cost if you have something.
If you have something similar or equivalent that too good a deal to miss, let me know ;
Or, if you see a rockin' special that might work, let me know too
Road disc groupset
- Prefer RS685/R8020 levers. Don't need calipers, as I'll probably use Zee again or even try the Hope RX4.
- Will look at SRAM CX1 single ring setup too
- Will also look at R785 Di2 Disc
- Frame is BB30, so if a crank is part of the offer, needs to be compatible (already have crank, but willing to look at options)
Compact Power Meter
- current crank is pre-2016 SpecialiSed carbon, so a Quarq or P2M spider is good
- happy to have full PM crank
- will consider 52/36 Mid-compact, but no 130BCD please
Carbon Handlebars - 40 or 42cm width
- Current favourite bars are 3T Ergonova (flattened upper section- and RHM bend)
- Like the look of the 3T Aeronova bars
- don't like the classic or ergo drop bars. They need to be shallow drop
So, let me know if you have a deal or lead for me :D
Michael
