*** SOLD ***
FredBloggs
by FredBloggs
Bontrager Aeolus 3 D3 Tubular Wheelset - £250 GBP + Delivery charges at cost, TBC with buyer, estimated at £25 UK tracked.
For Rim brake only, fitted with:
Rear Tubular - Vittoria Corsa Graphene 2.0, 25mm, tub has less than 100 miles on it, as new with no nicks or cuts. Fixed with Effetto Mariposa Carogna tub tape.
Specs Below:
27mm wide
Aeolus 3 (35mm rim depth)
Super light at 1150g
Shimano/SRAM 11 speed freehub
Decals have been removed for stealth look
New bearings (rear wheel) & freehub body recently fitted
White DT Swiss hubs fitted with DT straight-pull Aerolite bladed spokes, 18 up front (laced radially), and 24 for the rear (2-cross for the drive-side, radial for the non-drive side) with external alloy nipples.
Barely used, in very good condition with light wear in braking surface, impeccable bearings and both wheels run true.
Very stiff wheelset
Supplied with Swiss stop Brake Pads
Tracked delivery or collection from village near Bolton
Full details and review below;
https://cyclingtips.com/2013/01/bontrag ... -tubulars/
