2017 BMC RM01 56cm Roadmachine 01 Dura Ace R9150 Di2 Disc
sled driver
by sled driver
2017 BMC RM01 RoadMachine
56cm Frame size
Full Dura Ace R9150 Di2 Hyd group
Reynolds ATTACK Carbon Clincher Wheel set
Includes new SM-BCR2 Charger/programmer
Asking $7,000 USD obo
The new BMC Roadmachine 01 is redefining what an endurance bike should be. Faster than a typical endurance bike, something you feel in the stiffness and aerodynamics. At the same time, offering greater comfort than a racing bike. The geometry reflects the desires of the engineers, racy but stable.
With the IC (Integrated Cockpit) the brake hoses & Di2 wires are completely routed internally for a clean modern look.
Available only with disc brakes, making it easy to fit up to 32mm tires.
Excellent condition, low mileage, less than a year old
$11,999 MSRP, paid over $13K, with tax
Specifications
•Frame - 56cm TCC 01(Tuned Compliance Concept), Premium Carbon
•Fork- Premium Carbon, Integrated Cockpit, 2cm tall cone installed (includes zero stack cone to "slam" the stem for lower rider position)
•Crank set - Dura Ace FC-R9100, 50-34T
•Cassette - Dura Ace CS-R9100, 11-30T
•Chain - Dura Ace CN-HG901-11
•Front Derailleur - Dura Ace Di2 FD-R9150
•Rear Derailleur - Dura Ace Di2 RD-R9150
•Shifters - Dura Ace ST-R9170, Di2 Hydraulic Disc Brake, Dual Control Levers
•Brakes - Dura Ace BR-R9170, Hydraulic Disc Brake Caliper
•Rotors - Dura Ace SM-RT900 Rotors (160 front/140 rear)
•Handlebar - 3T Carbon Ergonova Team - 44cm width
•Bar Tape - fi’zi:k. Performance Tacky Touch
•Stem - BMC ICS 01 - Integrated Cockpit Design,10cm length
•Seatpost - BMC "D" Premium Carbon, 15mm offset
•Seat - fi’zi:k. Antares R3 with Carbon rails
•Wheels - Reynolds Attack, Full Carbon tubeless Clincher, 29mm deep, 1480g weight
•Tires - Specialized S-Works TURBO 700 X 28 2Bliss (set up tubeless with sealant)
•Battery - Shimano BT-DN110 Syncro/Auto Shift compatible
•Charger- Shimano SM-BCR2
Total bike weight 16.07 lbs.
2018 BMC Teammachine SLR01 DISC, R9170 Di2, Dura Ace R9170-C40-TL
2017 BMC R01 RoadMachine, R9170 Di2, Reynolds Attack
2015 GT Grade, Ultegra Di2, Reynolds ATR
2010 S Works Epic, Sram XX1, Carbon Roval Control SL
