Looking for a new Cross frame and forks? Suggestions.
BmanX
by BmanX
I currently have an aluminum no name cross frame with the carbon Redline fork but I would like to make this into a city bike with flat bars and Paul's thumbies 10 speed maybe but more likely I will go with 9 speed 105 that is on the cross bike. Yes a light weight city bike. Stupid yes but I have a disease and it is called WWism.
The current build is around 19.75 lbs and the current frame is around 1650g and the fork is around 710g.
I would like to be able to drop the weight of the build down to around 18.5 lbs with just the frame and forks if possible. I will then most likely do the build around Ultegra 10. I already have an Easton EC90 post, Fizik Arione saddle, Syntace F99 stem, Easton EC90 carbon bars, Eggbeater Candy SL pedals and a FSA compact crank. So most of the parts are pretty light at this point.
The only parts that I am not sure about using is the crank set and the brakes. I am currently using the Tektro Mini V's and I really like the way they work but I might change them out for something lighter. The cranks are the FSA Energy which are pretty light for a non carbon crank. I will stick with a double up front and they currently have a 48t/34t set up.
So any suggestions on a good cross frame and fork (forks I might just go with the Easton since I am an Easton man).
