Most comfortable round seat post
hansotto089
by hansotto089
I am looking for a comfortable seat post to replace the stock ENVE seat post on the MOG. Should be as dampening as possible. Any suggestions?
edit: I would love to carry over my Split Leaf Canyon seatpost, but that one might be too short. Is only available in 345mm as far as I know. So looking for at least >350mm.
jemima
by jemima
I find the 30mm+ adjustable-setback, one-piece Canyon post very dampening. 60kg rider.
My other frame has a 15mm setback Ritchey WCS Flexlogic which doesn't damp as much.
Both 27.2mm.
Curve Grovel ti.
thirdsun
by thirdsun
hansotto089 wrote:
Sun Nov 24, 2024 9:59 pm
Nothing will come close to the performance and simplicity of the Canyon/Ergon VCLS seat post unfortunately. It's a great design in my opinion.
  • Canyon Aeroad CF SLX 8 Di2
  • Cervelo Caledonia Rival eTap AXS
  • Vitus Venon Evo
  • Canyon Grail CF SL 8 Di2
DrimeOser
by DrimeOser
I also think the Canyon/Ergon VLCS post is the epitome of flex posts. It takes the sting out of any ride. For me it was too whippy at the end, having somewhat too much movement. I ended up with the Specialized Roval Terra post that still is very comfortable but does not take it to the extreme.
CampagYOLO
by CampagYOLO
Canyon VCLS is brilliant, it's actually 350mm long as well if that helps.
There's other suspension seatposts out there by brands such as USE which are also longer but they generally come in at nearly twice the weight of the Canyon one.
I guess the other thing to do would be to max out tyre width, use a supple tyre and keep the pressures low, that often has more impact on comfort.
jfranci3
by jfranci3
The Canyon / Ergon post is the best by far. The 27.2 one is anyway; I tried the 30.9 one and it was stiff.
Prusoli
by Prusoli
Cannondale Save seatpost used to be condered as comfy seatposts.
Prusoli
by Prusoli
gloscherrybomb
by gloscherrybomb
VoiceVelo Vfv.
charirider
by charirider
Cannondale SAVE, 100%
Road: 2018 Cannondale SuperSix EVO gen2 rim size 56 (raw stripped) 6.72kg
CX: 2014 Bridgestone Anchor CX6 Equipe 105 rim size 55 9.03kg
jdms2k
by jdms2k
Yes, my old Canyon seatpost was excellent.
Right now, I surprisingly like my Roval Terra seatpost on gravel.
jeanjacques
by jeanjacques
On Schmolke website you will find two independant test that shows their seatpost seems the most flexible one (little bit better than the VCLS): https://www.schmolke-carbon.com/quality ... CXDx56Rexy
CJosephB
by CJosephB
Highly recommend Roval Alpinist Seapost .. high weight limit (I think it was 125kg), ability to adjust from 0 to 20mm offset. Can take round and oval saddle rails.
DeepLakeGiant
by DeepLakeGiant
Depends on how much seatpost exposed you have. At 85 kg and 27 cm exposed I found Ergon/Canyon VCLS to be way too flexy.
