Ridley ASTR RS
ill principe
by ill principe
Requiem84 wrote:
Wed Nov 13, 2024 10:36 am
I had a conversation with a Ridley dealer. The bare frame (unpainted, no handlebar etc) will cost:
ASTR RS: EUR 4099
ASTR (non-RS): EUR 1949
Pretty easy choice right? Non-RS version seems like the much better deal. According to Ridley it only is 90grams heavier. I suspect it might be a little less stiff due to the different layout, but that would actually be better for most non-professional riders.
Guessing unpainted in the base ASTR case are the three standard paintjobs? Orange, grey-matte and black sparkling? Or is custom-paint a obligatory option for framesets?
Current:
S-Works SL8 RTP | Diverge Comp Carbon
Retired:
S-Works SL7 | S-Works Venge | Ultimate CF SLX Mk IV | Ultimate CF SLX Mk III | S5 | R3 | Cento | ...
Requiem84
by Requiem84
Unpainted should be raw carbon look, no paint at all (I am thinking of custom painting).
joebusby
by joebusby
Spoke to a UK Ridley dealer. They mean painted black (gold decals) grey (dark grey decals) etc. prob lighter in black than RS in bright colour.
They do say 'non rs has less aero tweaks' but I don't believe it and can't see it on the frame.
£2000 was what I was quoted but no stock until next Feb at best.
eins4eins
by eins4eins
less aero probably means the round seattube and -post. You can probably measure the difference in a windtunnel, but its nothing i would pay an extra 2.000 for
spdntrxi
by spdntrxi
ASTR RS: EUR 4099
yeah leaning towards non-RS. I'll be wanting to use a dropper post anyways.. so it makes sense.
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault x2 drop and flat bar
Requiem84
by Requiem84
The non RS paint schemes do look at lot cheaper imo.
I'm still on the fence
cerro
by cerro
When will someone get the first one is the question. Haven't seen any out there except for the sponsored riders yet. Will hopefully get to see one irl in 2 weeks time.
joebusby
by joebusby
eins4eins wrote:
Fri Nov 15, 2024 12:41 pm
If you read the Ridley media it says the frameset itself has fewer aerofoiled sections. Can't remember where it was. I also doubt it though.
sunfire2k5
by sunfire2k5
I agree.. if that is all the difference the non rs will be good enough. Probably more comfort with 27.2mm seatpost also.
On Grifn vs grifn rs the RS is superior in terms of stiffness around the BB. Hopefully this is not the case with ASTR. The difference in price for frameset is probably big because they bundle seatpost AND new nimbus cockpit with the RS. Usually not included 27.2mm seatposts on frames from them.
FOIL 30 MY23, Ult+105 Di2, EXS Aerover 120/360, Newmen Allround Vonoa
Ridley ASTR RS - GRX Di2 2x12 - Nextie AGX45 - Terra Speed 45mm
Ridley X-Night RS GRX+105 Di2 1x12s
Requiem84
by Requiem84
What is the experience with the (new) Nimbus cockpit?
Requiem84
by Requiem84
Another downside are the fork/handkebar dimensions (or however you call it). It's 1.1/4 instead of the usual 1.1/8.
I suppose that rules out many other nice handlebar options? What would be a good alternative to the stock Nimbus cockpit?
spdntrxi
by spdntrxi
Requiem84 wrote:
Sat Nov 16, 2024 7:48 pm
really I missed that in any spec list. 1.1/4 is deal breaker for me. I'm out
cerro
by cerro
Isn't that just the bearing to get space for everything? The fork should be regular Ridley D-shaped so alla cockpits that work with that should work. Or I'm screwed ;)
Requiem84
by Requiem84
cerro wrote:
Sun Nov 17, 2024 4:30 pm
According to the technical specs it's the headset dimensions.
See here:
https://imgur.com/a/HveJBpy
treyxt
by treyxt
Specialized Tarmac SL7 10r 61cm (Raw Black Carbon) / r9170 Dura-Ace Di2 11sp / Lightbicycle AR46
Cannondale SuperSlice Hi-Mod 58cm (From EF) / r8050 Ultegra Di2 11sp / AeroCoach Ascalon Carbon / AeroCoach AEOX Zephyr
