Thanks for that - every day a school day!satanas wrote: ↑Mon Oct 21, 2024 4:22 amIf you get an i30 XC rim there may well be problems with tyres blowing off at your weight. Bear in mind these are intended for ~55+mm tyres at <30PSI. If you instead use 42mm tyres at much higher pressure they might not stay on, whereas the i25mm rims are intended to take tyres from ~29mm (current ETRTO lower limit) upwards, so should tolerate much more before blowing off.
I'm going around in circles here, spoilt for choice but unsure of priorities. And with Black Friday looming, I'd be mad to order anything before then.
Given that there is so much in the way of short burst acceleration in gravel racing, would prioritising weight be more sensible than aero? How much of an affect does aero have when knobbly gravel tyres are factored in?
Obviously, in a gravel race, you're likely to spent a lot more time in the wind than on the road, and the speeds are still fairly high (I expect I'll be around 33kph average, if I hope to qualify for the worlds). But if shaving several hundred grams off the spun mass has a bigger positive effect....
But then you're back to durability, and being a veritable lump, I ought to prioritise strength and durability.
This is a question with (I feel) a great many right answers, depending on your perspective.
And for perspective, this is me with my 2XL Canyon Grail
