Apologies for having missed your post and a belated happy birthday to you!TLN wrote: ↑Fri Nov 01, 2024 6:55 pmFinally a topic I can contribute
194cm and 100+ kilos rider. 35yo (today, actually).
Running multiple wheelsets:
Road: Terra CLX (1st version): 25mm internal, 32 external, 30C tires is perfect, currently running 32c, that bulge a bit. Hooked rim, dt--180 hubs, very happy about it.
Fast gravel: Duke Lucky Jack SLS4: 26mm internal, 28mm external. Currently with Challenge 36c tires, but I tried GP5000 in 32. Rim is hookless, so I'd rather stick with wider tire and lower pressure (low-40s). I've tried same rim with 40C gravel tire and that would be my choice for something fast. Surprisingly, not alot of difference going from 25mm internal to 28/26 when running same tires.
Experimental fun setup: light bike XC wheels, 30mm internal. Curently set up with IRC Boken in 40c, and measures ~45mm. 28 spokes (rest is 24 I believe). Currently on Grizl Suspension, so almost-mountain bike. I tried Pirelli Cinturato H in 50c: very comfortable and Spesh Fast trak in 2.2
Comfort-wise, I feel that XC-set up is way stiffer, but that's compensated with bigger tires (suspension fork and seatpost). On the other hand I know that I can ride careless on that wheelset: it's overbuild for gravel, plus I got it very cheap.
I haven't covered all combinations of tires/bikes, but for pure gravel, I'd go with 30c internal and stick with 40c-50c tires easily.
For road (~28-32c slicks) for 200lbs (90kg)+ 25mm internal is way to go. Going from 25c to 28c with 30c (or 32c) tires is barely noticeable. Tire pressure is far more important: sometimes you got it very right and it's very noticeable.
I'm very interested in setup described in "wide rim" topic, aka Nextie rims (29mm internal, hooked) with 30-32c slicks: sure it breaks all the rules but I feel that will be very comfy and fast for heavy riders on the road or gravel.
Thanks for sharing your experiences in detail. Unfortunately, I don't have the option to go wide on my road bike yet as I'm still on rim brakes. Our asphalt is incredibly smooth here, so there is perhaps less of an advantage, though my regular training partner is on 32mm on the road and he still flies (another 2m 100kg rider).
I'm still just a bit trepidatious about hookless rims. Hunt have a sale on their wheels now and their 35mm carbon gravel wheelset is on 650 euros. It's very tempting, but they are hookless.
What do you feel is the advantage of going from 25mm internal to closer to 30mm?
