Tideace Noah
Uberflo
by Uberflo
akira11 wrote:
Mon Nov 18, 2024 3:20 pm
Uberflo wrote:
Sun Nov 17, 2024 9:25 am
Bike is ready with 8,48 kg
https://imgur.com/a/xtagwv2
Clearance with 46T
https://imgur.com/a/dFdGWL2
ah, forgot to comment on this:
- bike looks sick!! congrats
- plenty clearance then, nice to know... although I think sram chainrings have a smaller diameter than Garbaruk's... decisions
Thanks but for the tyre clearance I dont think 50c will fit on the Nextie rims. I have the Overlands in 40 mm which are about 42-43 mm on that rim.
akira11
by akira11
yeah I'm aware pretty much any tire ends up wider on the nexties, that's why I went with thunderos in 44mm nominal width. they should blow out to almost 47mm i think
If I like them, I might try thunderos 48mm in the future to get up to 50mm wide
#savetherimbrake
gloscherrybomb
by gloscherrybomb
akira11 wrote:
Mon Nov 18, 2024 10:46 pm
I'm running Thundero 48s (HD) on super wide rims that measure out to 50mm. Loads of space.
SEDK
by SEDK
Hi all,
I am much considering a Noah but the sizing is giving me quite some headache.
Gravel wise I come from a Trek Checkpoint Alr and the Noah geometry is completely different. I am 183-ish with an inseam of 88 and currently ride a size 56 with slammed stem and an 100mm stem.
From geometry geeks I could go for a 54 with ~20mm stem spacers or a 56 with slammed but short stem.
My current set-up on the Trek is relatively new and not finally adjusted - looking for a good compromise between comfort and sport.
Anybody else here around my size and what have you chosen?
gloscherrybomb
by gloscherrybomb
I'm 182 and run a 54 with a 100mm stem. Probably my most comfortable geometry bike.
akira11
by akira11
gloscherrybomb wrote:
Tue Nov 19, 2024 10:01 am
awesome! :beerchug:
#savetherimbrake
Mr.Gib
by Mr.Gib
@SEDK, I think with your preference for a shorter reach the smaller bike might be the better choice. 20mm of spacers is OK. The only strong opinion I have about gravel bikes is that toe overlap is a crime punishable by death. My guess is that the 4mm difference in length between the two won't be a deal-breaker in this regard. FWIW I am the same height with same inseam as you, but I would be better with the bigger frame due to my preference for longer reach.
akira11
by akira11
good news yaay
the nexties arrived today after a long month and a half of waiting...
these rims are shockingly wide in person woah!
very good finish and they weigh 1447g, not too shabby
almost there with my build, now waiting for black friday to get the last parts :mrgreen:
#savetherimbrake
MrRolandos
by MrRolandos
Hehe yeah what would you think about 29 internal :D Nextie are solid quality!
My cover has been shipped, hopefully will be here soon! :D
SEDK
by SEDK
Mr.Gib wrote:@SEDK, I think with your preference for a shorter reach the smaller bike might be the better choice. 20mm of spacers is OK. The only strong opinion I have about gravel bikes is that toe overlap is a crime punishable by death. My guess is that the 4mm difference in length between the two won't be a deal-breaker in this regard. FWIW I am the same height with same inseam as you, but I would be better with the bigger frame due to my preference for longer reach.
Thanks for input - I have a size 47 so the risk is certainly thereImage
melkart
by melkart
Hello,
I am planning to buy this frame to TanTan.
I will go with a Sram mullet transmission (red e1 shifters, force d2 powermeter with 40 or 42t and GX T-Type derailleur.
I don't know if I need wide or regular cranks for this system.
Can somebody help me?
Thank you in advance
Uberflo
by Uberflo
Due to the tyre clearance you should opt for a Wide crank
akira11
by akira11
melkart wrote:
Fri Nov 22, 2024 4:37 pm
Hello,
I'm also going for the mullet build and installed wide xplr cranks
#savetherimbrake
Uberflo
by Uberflo
Requiem84
by Requiem84
Uberflo wrote:
Sun Dec 01, 2024 7:57 pm
First Ride: https://imgur.com/a/kWx7LtN
Nice! First thoughts on the bike?
