Nice! Just another week and you are in business! Handlebar looks good, a bit like my black inc bar. Also lightweight. Whats the price on it?Requiem84 wrote: ↑Tue Nov 12, 2024 9:12 amMy frame finalllyyy has shipped. Yay.
Also bought a bit of an experimental (road) handlebar as I dig the looks.
https://www.ornanbike.com/ultralight-ae ... _p189.html
Tideace Noah
interesting bars, let us know how you like them.Requiem84 wrote: ↑Tue Nov 12, 2024 9:12 amMy frame finalllyyy has shipped. Yay.
i ended up getting the carbon copycat bars from the scott addict gravel: https://aliexpress.com/item/1005006728112353.html
380 at the hoods, 460 at the drops, with ultra short 60mm reach to compensate for the noah huge toptube, this way i can run a longer stem
only parts left for my build are the nextie wheels, shipping is taking way too long
#savetherimbrake
Probably with a spacer or so. It should work I guess. I run my 50/34 without any issues and without any extra spacers.
I got https://nl.aliexpress.com/item/10050077 ... pt=glo2nld this guy yesterday. I ordered Pitch 1.5 UDH 1PC as TideAce has a 1.5 stock in it. Looks way better then the regular mount. I guess if you are running SRAM UDH it doesnt matter but yeah for us Shimano boys
Also got an adjustable mount to face downwards, not ideal but looks way better already!
I'm using 46T with a Magene P505 base. I run a very thin spacer to give it a bit of space away from the chainstay.
please let me know how it goes and how much clearance is left as I also have a sram wide crank
chainring diameter varies a lot depending on the manufacturer... I think wolf tooth's 46T chainring would fit (192.7mm) while garbaruk 46t (196.1mm) won't
#savetherimbrake
Would using a 105 di2 front derailleur hurt the tire clearance on this frame?
Specialized Tarmac SL7 10r 61cm (Raw Black Carbon) / r9170 Dura-Ace Di2 11sp / Lightbicycle AR46
Cannondale SuperSlice Hi-Mod 58cm (From EF) / r8050 Ultegra Di2 11sp / AeroCoach Ascalon Carbon / AeroCoach AEOX Zephyr
Bike is ready with 8,48 kg
https://imgur.com/a/xtagwv2
Clearance with 46T
https://imgur.com/a/dFdGWL2
Clearance with 46T
Yes, maybe because of the stand in the back. Will Check this later as I finished the bike at 2:30 am.
This is how I fixed the issue with the Headset top cap rubbing the Frame with the Tideace handlebar. I shortened three shims so they do not cut into the brake hoses
https://imgur.com/a/UjIyPF9
Ah need! That works? No play etc? I used elektrical tape around the hoses, should work I guess. We shall see in the future. For now its all fine.
Just got my sworks power mirror saddle and installed. Bit Iess weight and more comfort. I always mount them at 180 degrees / flat, works great for me.
Just need the painted cover but not shipped yet.
