Are GRX 810 and 820 cranksets the same?
zachspeed
by zachspeed
Are GRX 810 (11-speed) and GRX 820 (12-speed) the same? Will GRX 810 work with the GRX 825 12-speed group?
harblhat
by harblhat
Arms are virtually the same, chainring spacing is different. 12s rings are closer together. 810 crankset (ie 11s rings) will work with 825 FD but shifting will not be perfect.
zachspeed
by zachspeed
harblhat wrote:
Tue Jun 11, 2024 2:06 pm
Thanks. That is what I thought
pdlpsher1
by pdlpsher1
The chainring spacing difference is 0.35mm, with the difference made on the big ring (less machined cutout such that the big ring sits 0.35mm closer to the small ring).
LainOTN
by LainOTN
Adding to the comments below, I asked a powermeter brand about availability of dual sided FC-RX820 and the answer was:
We are currently not fitting a double sided one on the RX820 but the RX810 due to the gears being a little thicker and hooking up to our measurement
wannabefast
by wannabefast
Actually the arms are just virtually the same, they are exactly the same. Even has the same part number. The chainrings spacing are slightly different, though, as others have stated.
zachspeed
by zachspeed
wannabefast wrote:
Thu Jun 13, 2024 2:37 pm
Does that mean, that if you take the 810 arms and put on 820 chainrings, you have an exact 820 crankset?
Nomadmax
by Nomadmax
Can you use the new 12 speed double crankset on an otherwise 11 speed GRX drivetrain?
pdlpsher1
by pdlpsher1
zachspeed wrote:
Fri Jun 14, 2024 9:56 am
Yes.
pdlpsher1
by pdlpsher1
Nomadmax wrote:
Fri Jun 14, 2024 10:29 am
Yes.
Nomadmax
by Nomadmax
Thank you!
