Campagnolo EKAR Pull Ratio
VonPG
by VonPG
After using my Caliper to measure ekar sprocket distance and cable pull distance I calculate the ekar pull ratio
each sprocket distance: 3.36mm
each cable pull distance: 2.42mm(Not too accurate, I may measure it again in the future)
Pull ratio for Campy Ekar ≈ 1.28
Not compatible with any other groupset.
(similar to sram 1.33? I am not sure)
graeme_f_k
Shop Owner / Manufacturer
by graeme_f_k
VonPG wrote:
Mon May 01, 2023 3:23 pm
each cable pull distance: 2.48mm(Not too accurate, I may measure it again in the future)
Pull ratio for Campy Ekar ≈ 1.35
If you'd asked, we could have saved you a lot of trouble ...
VonPG
by VonPG
graeme_f_k wrote:
Tue May 02, 2023 1:15 am
Wow, do you have accurate data? I have searched a lot of information but they still lacks some groupset pull ratio
(https://www.mtb-news.de/forum/attachmen ... f.1415361/)
this is currently have the most complete information about pull ratio but still lacks some like cp ekar, cp new 11s+
JenShawn
by JenShawn
The pull ratio for Campy Ekar is approximately 1.35, which is not compatible with any other groupset and is similar to SRAM's 1.33 pull ratio. However, due to the inaccuracy of the cable pull measurement, it is recommended to measure it again for more accuracy.
VonPG
by VonPG
FreaK
by FreaK
This feels like another reason to investigate the Growtac Equal levers. I really miss being able to mix and match stuff.
it's actually possible to come to the conclusion even before realising it makes no sense at all
tymon_tm
satanas
by satanas
^ It remains to be seen whether the Growtac levers will be reliable and - if you want indexing - whether that works, and what will be supported. It seems like it'll be at least several months before we have any real idea how good or bad they might be, and IMO there are ergonomic questions too.
Vespasianus
by Vespasianus
Anybody know if the SRAM 13 speed cassette would play nicey with EKAR? Lot more expensive but also lighter....
Too many bikes, too little time.
satanas
by satanas
Vespasianus wrote:
Thu Nov 28, 2024 3:03 pm
Can't see it being possible. SRAM uses 12 speed spacing and fits the extra cog into the space made available by the thinner RD mount. Ekar uses <12 speed spacing and a narrower chain.
