Shimano 12 speed GRX part list RX820/RX822/RX610 (mechanical)
ooo
by ooo
ooo wrote:
Wed May 24, 2023 1:44 pm
update:
grx 12s rear deraileur compatibility with direct mount hanger:
RD-RX820: DM hanger compatible
RD-RX822-GS: DM hanger NOT compatible
RD-RX822-SGS: DM hanger NOT compatible
grx 12s chainrings:
1x12 FC-RX610-1 40 and 38 - new size (there is no 38 for 1x11 grx)
1x12 FC-RX820-1 42 and 40
2x12 FC-RX610-2 46-30
2x12 FC-RX820-2 48-31
grx 12s shifters:
2x12 ST-RX610 (1x12 BL-RX610-L)
2x12 ST-RX820 (1x12 BL-RX820-L ST-RX820-LA)
grx 12s wheels:
WH-RX880 microspline - compatible only with 12-speed mtb cassettes, there are no grx microspline cassettes
WH-RX880 non-microspline - first non-dura-ace wheels with 12-speed shimano road specific freehub body HG spline L2
(compatible with 12-speed road cassettes and CS-HG710; NOT compatible with 11-speed road cassettes and CS-HG800)
12-speed GRX part list:
Wheel Set Gravel SHIMANO GRX:
EWHRX880LFERED70
EWHRX880LFEREDMS70
WH-RX880-700C 12mm E-thru Tubeless For 12-Spd 100/142mm
WH-RX880-700C 12mm E-thru Tubeless For 12-Spd 100/142mm Micro Spline
Front Derailleur Gravel SHIMANO GRX:
IFDRX820F
FD-RX820 12-Spd Down Swing Down Pull Brazed-On For 48T
Rear Derailleur Gravel SHIMANO GRX:
IRDRX820
IRDRX822GS
IRDRX822SGS
RD-RX820 12-Spd Direct Attachement
RD-RX822 GS 12-Spd Direct Attachement
RD-RX822 SGS 12-Spd Direct Attachement
Disc Brake Assembly Gravel SHIMANO GRX:
IRX8202DRRDSC170A
IRX8202DLF6SC100A
IRX8204DLF6SC100
BR/ST-RX820 12-Spd J-kit w/ Fin Rear
BR/ST-RX820 J-kit w/ Fin For Double Front
BR/BL-RX820 160mm J-kit w/ Fin For Single Front
Disc Brake Gravel SHIMANO GRX:
IBRRX820F6RF
IBRRX820RDRF
BR-RX820 Hydraulic For 160mm Rotor w/ Fin Front
BR-RX820 Hydraulic For 160mm Rotor w/ Fin Rear
Chainwheel Gravel SHIMANO GRX:
IFCRX8201CXB0
IFCRX8201DXB0
IFCRX8201EXB0
IFCRX8201CXB2
IFCRX8201DXB2
IFCRX8201EXB2
FC-RX820-1 w/o BB 40x170mm 12s
FC-RX820-1 w/o BB 40x172.5mm 12s
FC-RX820-1 w/o BB 40x175mm 12s
FC-RX820-1 w/o BB 42x170mm 12s
FC-RX820-1 w/o BB 42x172.5mm 12s
FC-RX820-1 w/o BB 42x175mm 12s
IFCRX8202CX81
IFCRX8202DX81
FC-RX820-2 w/o BB 48x31x170mm 12s
FC-RX820-2 w/o BB 48x31x172.5mm 12s
this is gravel specific part list, other components are shared from road and mtb groups
see also: 105 R7100 mechanical part list
Woland
by Woland
ooo wrote:
Sun Mar 19, 2023 9:03 am
Rear Deraiof lleur Gravel SHIMANO GRX:
IRDRX820
IRDRX822GS
IRDRX822SGS
A quick google search suggests that the GS derailleur has a capacity of up to 45t and the SGS up to 51t.
ooo
by ooo
RD-RX820 for 2x12 with 11-36T or 11-34T
RD-RX822-GS for 1x12 with 10-45T
RD-RX822-SGS for 1x12 with 10-51T
ultimobici
by ultimobici
ooo wrote:
Sun Mar 19, 2023 9:51 am
No Di2 variations yet?
RDY
by RDY
Probably means that the GS will work in 2x12 50/34 with that tasty looking Ingrid 11-44 cassette ...
ooo
by ooo
no hints on di2, except one unreliable source
no weightbtet
pricelist:
€50 FD-RX820
€105 RD-RX820, RD-RX822 GS/SGS
€365 BR/ST-RX820 12-Spd J-kit w/ Fin Rear
€360 BR/ST-RX820 J-kit w/ Fin For Double Front
€320 BR/BL-RX820 160mm J-kit w/ Fin For Single Front
€260 ST-RX820-R (ISTRX820RBI)
€260 ST-RX820-L (ISTRX820LI)
€215 BL-RX820-L (IBLRX820L)
€240 ST-RX820-LA (ISTRX820LAI)
€70 BR-RX820 Front (IBRRX820F6RF)
€65 BR-RX820 Rear (IBRRX820RDRF)
€235 FC-RX820-2, FC-RX820-1
harblhat
by harblhat
Are there no cranks shorter than 170? Even 105 is now offered down to 160.
ooo
by ooo
it is the same as previous generation GRX:
FC-RX810-11 175, 172.5, 170
FC-RX820-12 175, 172.5, 170
oem cranks may be avaible in 165:
FC-RX600-11 175, 172.5, 170, 165
FC-RX610-12 ???
pdlpsher1
by pdlpsher1
All of the latest 12-speed groups have 160 available. It's weird the GRX doesn't get the same treatement. Not that it matters for me anyways. I'm already on 155s.
pdlpsher1
by pdlpsher1
Too bad there's no 11-40 2x option.
spdntrxi
by spdntrxi
pdlpsher1 wrote:
Mon Mar 20, 2023 5:01 am
I agree steep gravel sweetspot for mortals.
2019 BMC TM01R
2002 Moots Compact-SL
2019 Parlee Z0XD
2020 Parlee TTiR
pdlpsher1
by pdlpsher1
Lol. Shimano even has a webpage on short cranks. I guess they believe gravel riding needs longer cranks because rock strikes add excitment to gravel riding.
https://road.shimano.com/us/stories/short-crank-curious
otnemem
by otnemem
No Di2, no party. Not to mention their lagging on the MTB front, that should put the braintrust on notice.
RDY
by RDY
As they're doing a mid length (GS) derailleur, I'd guess it'll work fine in 2x with a road front derailleur, as current GRX does. There was some expectation that there'd just be a short and long (i.e. SGS) option, neither of which might work with between road & MTB cassette sizes and 2x.
Ritxis
by Ritxis
otnemem wrote:
Mon Mar 20, 2023 8:39 am
Presumably there will also be a Di2 version.....I suppose Shimano will launch with the 2 versions
Perhaps the mechanical version would be more advanced in terms of design/production/distribution so that the list of parts is "known before... when some brand already "filtered" bicycle specifications with it...also that when removing the mechanical 105, the differences in certain parts (mechanical/hydraulic internal mechanism) of the shifters are the same
It would be a serious mistake by Shimano not to release the Di2 version or to do it much later than the mechanical version.
