THM M3 spindle issue
- eliflap-scalpel
- Contact:
Tried to install my M3 on a BMC URS bike with 4130 press fit bb.
The spindle is nor able to fit the bearings
Inviato dal mio iPhone utilizzando Tapatalk
http://eliflap.it/
- eliflap-scalpel
- Contact:
Crank is a beautiful piece of art
The 40T CarbonTi ring matches it perfectly
http://eliflap.it/
- eliflap-scalpel
- Contact:
But 2 pairs of bearings do not fit the spindle
http://eliflap.it/
- eliflap-scalpel
- Contact:
Wrote to THM yesterday.
Any suggestions?
Any suggestions?
http://eliflap.it/
Try using some grease to help, it’s a tight fit but I’ve never had any issues using any 30mm bearings.eliflap-scalpel wrote:Wrote to THM yesterday.
Any suggestions?
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
- ultimobici
- in the industry
- Contact:
I presume the crank is new. Is the BB new too?eliflap-scalpel wrote: ↑Sat Mar 11, 2023 10:29 amWrote to THM yesterday.
Any suggestions?
Have you measured the axle to see what the difference is?
- eliflap-scalpel
- Contact:
i tried Wheels Manifacturing, SRAM and Rotor bearings with no luck ...
will try with grease, rubber hammer and book to save carbon arm
http://eliflap.it/
- ultimobici
- in the industry
- Contact:
Have THM not replied? I'd wait just in case they have a better solution. Perhaps the axle is out of spec?eliflap-scalpel wrote: ↑Tue Mar 14, 2023 2:00 pmi tried Wheels Manifacturing, SRAM and Rotor bearings with no luck ...
I have found this to be a common issue with BB30/PF30 cranks and bearings and while freezing the spindle may allow insertion, if there is any binding such that you need to bang on the crank with a rubber mallet to get it inserted, that is most certainly going to seriously distort the inner races of the BB bearings. I have always felt that either the BB30/PF30/BB386 standard is not clear as more often than not the spindle ends up being oversized by .2 - .3 mm. My solution when installing an SRM Hollogram powermeter with a Cannondale BB30 spindle was to use very fine grit Emory cloth and 'wet polish' the spindle enough that a few microns of material are removed to the point that the spindle could be inserted by hand with only a moderate amount of effort.
- Michael
- eliflap-scalpel
- Contact:
Solved
Done 30 minutes with 800 sand paper on the spindle and a small amount of vaseline, it will fit.
http://eliflap.it/
Good to know. I'm waiting for my THM crankset to arrive.
