Hi all,
For those who have an OPEN U.P., are any of you having trouble with the seat tube getting pinched by the seatpost collar when set up in the recommended position (clamp facing forwards)? I'm on my second U.P. with that issue. The seatpost clamp deformed the seat tube so much that the layers started to separate on the first one. The second one just got built up and that area has already started to squeeze a bit. I've reversed the clamp so that the slit on both the seat tube and also the collar are lined up which should solve the issue but I am wondering if this is a common problem? Thanks!
OPEN U.P. Seattube
It's a known issue. Best bet is to get a seat collar that doesn't have the tab so you can install it facing backwards and not forward, so the seat clamp area isn't at a location which could cause bunch up.
Hi all,
I've just go my UP two weeks ago, and that's a bit scary. (And my english is pretty basic)
Can you confirm that I haven't done a mistake setting up my collar seat this way?
It can be bad for the frame?
Thanks in advance, I appreciate it.
The pic that you have included is how my frame(s) were set up initially. That is the way OPEN recommends the clamp to be set up but also the way that made my frame bulge. I have since turned it the other way which OPEN is also okay with.jeffreybeaumont wrote: ↑Fri Nov 18, 2022 1:43 pmHi all,
Thanks for your answer!trainergav wrote: ↑Fri Nov 18, 2022 6:18 pmThe pic that you have included is how my frame(s) were set up initially. That is the way OPEN recommends the clamp to be set up but also the way that made my frame bulge. I have since turned it the other way which OPEN is also okay with.jeffreybeaumont wrote: ↑Fri Nov 18, 2022 1:43 pm
Is something that is covered by the frame warranty in your case?
