I would like to change the RockShox suspension fork that came on my MY21 Grizl with a fixed fork, but I'm having issues with finding a replacement fork with 1-1/4 to 1-1/2 steerer.
The only forks that I found were with 1-1/8 to 1-1/2 steerer.
Axle to crown will also be a small issue, as the current RockShox fork has 415mm and the standard gravel forks have 395mm, so around 10mm shorter (considering also 20% sag)
Did any of you had more luck with finding an alternative?
In the worse case was thinking of buying an adaptor from 28.6mm to 31.8mm for the upper bearing (and changing the stem to a standard one).
Canyon Grizl fork (steerer 1-1/4 to 1-1/2)
