Thanks for your reminder. I used to think it shuold have the same parameter as Other Chinese Open mould like Spcycle G056 or TanTan GR047 because they have the same geometry.
that "perfect" gravel bike
I managed to get my 2020 Giant Revolt Advanced to 17.99 lbs - full weight with pedals & garmin mount. Mine was built around an Ultegra 2X drivetrain.
The newer 2022/2023 models are 160 to 200 grs lighter depending on which model once picks - Advanced or Advanced Pro
This model offers the potential to end up under 17 lbs & will be less expensive than other "brand name" manufacturers.
2020 Giant Revolt Advanced 0
2016 Giant TCR Advanced SL
2014 Santa Cruz 5010 CC
Check the Revolt built by user OnTheRivet - 16.97 lbs, with SRAM Red Etap AXS - 1X - really nice build!
I built this one for a ride buddy .. Cervelo Aspero 54cm with Force axs 1x xplr, zipp 303s with panaracer gravelking 700x38 around 17lbs, with lighter saddle, handlear and stem . .it could probably go down to less than 17lbs.
2020 Colnago C64 Mapei - SR12 EPS - LW Meleinstein
2022 Ridley Kanzo Adventure Rival/GX AXS
2021 Basso Diamante SV - SR12 Disc EPS - Bora WTO 60
2022 Basso Palta 2 - Rival/GX AXS - Zipp 303s
I was considering to build Crux for myself as winter/gravel bike.
No i am considering also Grizl, because it has pretty good fender mounts, and fenders from Canyon look really acceptable on the bike.
https://www.canyon.com/cs-cz/gear/acces ... v_farbe=BK
I can't stand the look and behavior of velcro fenders!
Are there some cool gravel framesets with direct mount fenders? I also had Factor LS which had holes for fenders, but Factor technical support was useless and they didn't suggest what direct mount fenders i should use and pushed me to purchase velcro. (SKS SpeedRocker - shite)
S-Works SL7 Dusty Blue 56cm @ Sram RED AXS Quarq, ZIPP 404 Firecrest, MCFK Aero Handlebar, PD-R9100 (7.2kg)
S-Works Epic 2022 Gloss Fluid L @ Sram XX1 AXS Quarq & Berg Ratheberg & BikeYoke Divine SL, Xpedo M-Force 8 (9.9kg)
You will probably get wet feet very easy because the front fender isn't long enough.req110 wrote: ↑Tue Nov 22, 2022 6:26 pmNo i am considering also Grizl, because it has pretty good fender mounts, and fenders from Canyon look really acceptable on the bike.
I know about that. I would use extenders, no worries.jayjay wrote: ↑Tue Nov 22, 2022 11:34 pmYou will probably get wet feet very easy because the front fender isn't long enough.req110 wrote: ↑Tue Nov 22, 2022 6:26 pmNo i am considering also Grizl, because it has pretty good fender mounts, and fenders from Canyon look really acceptable on the bike.
have you look on the Ridley Kanzo Adventure bike, i'm waiting for my frameset and will be building one with sram axs .
40mm max tire; 6 years old already; no integrated cabling if you want it; what was a very 'progressive' bike when released could have the HTA backed off another degree and STA increased another degree in the largest sizes now.spartacus wrote: ↑Mon Oct 31, 2022 4:48 pmHakka MX
edit: IDK why everyone always ignores these. They're light, stiff, and use normal parts, and people win on them
https://www.velonews.com/gear/gravel-ge ... -hakka-mx/
Almost certainly they'll replace it next year now that they refreshed the paintjobs for MY2023. But if they update it for MY24 to 46-50mm max tire, 1.5" straight steerer tube, and do as above with the the HTA / STAs, then it would be top of my shopping list ...
That's an excellent general purpose gravel bike, I have one, but I would not say it's a sharp gravel racer. It has the clearance and fitments to go adventuring on - hence the name. The frame is a Carbonda 696.
cycling / nature / music
I actually got the newest version of the Kanzo Adventure ..not sure if thats the same one .
Prolly not perfect, but saw this and thought of this thread:
https://www.bikeradar.com/features/pro- ... on-exceed/
It's a very cool, purpose-built idea...I like it!
