Bubbles / bulges in my Specialized Pathfinder S-Works tire
jacobeh
by jacobeh
Hi, has anyone experienced something similar in their tires? I'm quite puzzled what's causing this since there isn't anything obvious on the inside of the tire that could indicate any leaks or tears (it's brand new)
I had it installed at a max of 3 bars to get them to "pop" on the wheel (tubeless) so it's well within the 2.5-4.5 bar specs of the tire
I have another set of Pathfinder S-Works that haven't exhibited this issue, however I've noticed they loose more air over time than the Pros - so maybe the thinner rubber / walls of the S-Works could be the culprit?
kode54
by kode54
Appears to be a defect. Are these wear indicators on the tire?
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
jacobeh
by jacobeh
kode54 wrote:
Fri Oct 28, 2022 11:22 am
I agree and I've already got a replacement by the shop without any hassle, but was just wondering if others had experienced the same
No, the wear indicators are on the middle "slick" part of the tire
bigfloor
by bigfloor
Had a similar problem with my GoodYear Eagle F1 tubeless tyre, bubbles on the surface after around 3000km (1900mi).
Sent from my SM-T860 using Tapatalk
