CX chainrings
They have Ultegra level 46/36 rings. You can just swap out the inner ring for a 39. The outer is the only special ring.
Specialized Tarmac SL7
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
Thanks, I'll have a look at it.LanceLegstrong wrote: ↑Tue Oct 25, 2022 10:22 pmThey have Ultegra level 46/36 rings. You can just swap out the inner ring for a 39. The outer is the only special ring.
insta: @fbonde
Where have you seen Ultegra R8100 level "cross" 46t outer rings?LanceLegstrong wrote: ↑Tue Oct 25, 2022 10:22 pmThey have Ultegra level 46/36 rings. You can just swap out the inner ring for a 39. The outer is the only special ring.
They occassionally pop up for sale on eBay, but DA-level CX rings are generally pro-only. I had a set of DA9000 rings, which I recently sold. DA rings are just Ultegra rings that lack the annondizing or are annodized to look like DA rings. They aren't hollow, like the larger rings, either.
Also, it doesn't look like Shimano has released a set of 46T rings for 8100.
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
I've been running the 12sp chain for years on an otherwise 11sp drivetrain. Works fine.
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
