What is the most advanced gravel bike do date?
- wheelsONfire
What is the most technically advanced gravel bike to date?
Anyone that have an idea?
Bikes:
Open *UP* (2016.04.14)
Most advanced to do what? Because almost by definition, gravel bikes are a compromise. If you want a very light and stiff bike, just put 32mm tyres on a modern road bike. If you want the most capable bike offroad, then a mountainbike. All gravel bikes fall somewhere in between, but still, what does "technically advanced" mean?
Do we care about aero? because some are doing that.
If weight matters most, then bikes CX like the Specialized Crux or Giant TCX can be good gravel bikes and the frames are very light.
For bike packing or very long races, having plenty of mounts might be helpful. It's not like putting threads on a frame is the most technically advanced thing in the world, but if you need them, it's good to have them.
Then there are brands that are starting to do gravel suspensions. That could be considered progress, but mountain bikes have had that for ages, and it's not clear that they are a worthy trade off on gravel.
At the end tyre choice is probably the most important thing in the bike, so of course clearance for the tyre you want to run should be the priority in any case.
- andreszucs
- in the industry
Do date, is mine.
My stuff on sale https://www.ebay.com/sch/andreszucs/m.h ... pg=&_from=
- andreszucs
- in the industry
- andreszucs
- in the industry
I mean, for one to believe that an axle standard is any better than adding suspension…ooo wrote:Road boost gravel bikes are most advanced, like Focus Atlas with front 110x12 and rear 148x12.
Non road boost gravel bikes are becoming obsolet and incompatible with stiff road boost wheels
- andreszucs
- in the industry
I think using Boost rear the way it now is overkill for gravel, but I see the benefit of 148mm spacing for add more gears! The purpose of boost is to have more width between flanges and build a stiffer wheel for classes like All mountain and Enduro since it goes airborne often. Now for gravel, different needs. Gravel wants high efficiency on the road (small jumps between cogs at high speed) and also able the clear the big hills. 148mm would allow 6.5mm extra free hub space to add gears if the flange spacing would stay the same as standard, 15 speeds, 16 speeds, maybe more.kervelo wrote:That must be the reason we always have so many riders with their Atlas bikes on the starting lines of major gravel events.
Moving to the boost rear may be a bold move, but so far it has no support from other brands.
Also boost and super boost add tire clearance/size which is probably more important than adding gears.andreszucs wrote: ↑Sun Jun 12, 2022 5:14 pmI think using Boost rear the way it now is overkill for gravel, but I see the benefit of 148mm spacing for add more gears! The purpose of boost is to have more width between flanges and build a stiffer wheel for classes like All mountain and Enduro since it goes airborne often. Now for gravel, different needs. Gravel wants high efficiency on the road (small jumps between cogs at high speed) and also able the clear the big hills. 148mm would allow 6.5mm extra free hub space to add gears if the flange spacing would stay the same as standard, 15 speeds, 16 speeds, maybe more.kervelo wrote:That must be the reason we always have so many riders with their Atlas bikes on the starting lines of major gravel events.
6mm larger tires goes a long way in terms of traction and tire suspension.
- andreszucs
- in the industry
Tires bigger than 38mm starts to make a gravel bike slow on road, at that point I would want a mtb to do a better job on the dirt!yinzerniner wrote:Also boost and super boost add tire clearance/size which is probably more important than adding gears.andreszucs wrote: ↑Sun Jun 12, 2022 5:14 pmI think using Boost rear the way it now is overkill for gravel, but I see the benefit of 148mm spacing for add more gears! The purpose of boost is to have more width between flanges and build a stiffer wheel for classes like All mountain and Enduro since it goes airborne often. Now for gravel, different needs. Gravel wants high efficiency on the road (small jumps between cogs at high speed) and also able the clear the big hills. 148mm would allow 6.5mm extra free hub space to add gears if the flange spacing would stay the same as standard, 15 speeds, 16 speeds, maybe more.kervelo wrote:That must be the reason we always have so many riders with their Atlas bikes on the starting lines of major gravel events.
Boost is completely unnecessary for gravel, a standard wheel is plenty stiff for the intended modality.
I vote for more gear, 15sp 9-46t or 10-50t (for the 9T haters), would allow for a super fine resolution while coasting at fast pace.
I have a E13 TRS Race or whatever cassette.. yeah I hate the 9T
2024 BMC TeamMachine R Building
2018 BMC TImeMachine Road
2002 Moots Compact-SL- getting aero look makeover
2023 Pivot E-Vault - completed project, full Xplr package
For YOUR USES 38mm seems like the inflection point between "gravel" and "mtb" but for others it's different. Also in some cases for other riders they'll use the extra tire size for better traction/suspension while not needing the on-road compromises of a MTB.andreszucs wrote: ↑Mon Jun 13, 2022 1:50 amTires bigger than 38mm starts to make a gravel bike slow on road, at that point I would want a mtb to do a better job on the dirt!yinzerniner wrote:Also boost and super boost add tire clearance/size which is probably more important than adding gears.andreszucs wrote: ↑Sun Jun 12, 2022 5:14 pmI think using Boost rear the way it now is overkill for gravel, but I see the benefit of 148mm spacing for add more gears! The purpose of boost is to have more width between flanges and build a stiffer wheel for classes like All mountain and Enduro since it goes airborne often. Now for gravel, different needs. Gravel wants high efficiency on the road (small jumps between cogs at high speed) and also able the clear the big hills. 148mm would allow 6.5mm extra free hub space to add gears if the flange spacing would stay the same as standard, 15 speeds, 16 speeds, maybe more.kervelo wrote:
Again, everyone's different but completely dismissing other viewpoints because they're note exactly aligned with yours is foolish.
Some could say your 15 speed idea is foolish, especially since you can effectively get that many gears with a GRX setup without having to change any freehubs standards, or design a new cassette/chain/ring/derailleur combo.
https://bikepacking.com/gear/wide-range-grx-2x11/
http://ritzelrechner.de/?GR=DERS&KB=30, ... H&DV=teeth
But I wouldn't because I'm sure you have your reasons for wanting something that is at least a few generations away.
- andreszucs
- in the industry
I’m sure you’re referring to other comments before mine as well, because I also felt dismissed. Also, I’ve used ‘I VOTE’…meaning, I respect other ideas, but I vote for mine, democratic.yinzerniner wrote: Again, everyone's different but completely dismissing other viewpoints because they're note exactly aligned with yours is foolish.
Road Boost is IMHO a totally pointless and extremely annoying attempt at planned obsolescence and proprietary parts lock in. All it really achieves is worse heel clearance, almost zero front hub options, higher Q factor, etc. Maybe if you're trying to build a bike with AXS + 2x and wide tyres the extra FD to tyre clearance might be useful but otherwise I can't see any point at all, and will be diligently avoiding it.
As for "most advanced" that depends on what matters to you - aero, suspension, tyre clearance, weight, something else???
