What is the most advanced gravel bike do date?
There's not really a "most advanced" for gravel. Tire clearance and geometry are what matter most in the frame itself. You can always run smaller tires but you can't run bigger. You need to be able to run 45's to shred most legit gravel. You can also throw 32's Gp5k for fast road only rides. That's what matters IMO. If you can't run big tires, then it's dated. Boost is a waste for gravel and not catching on.
Moots Vamoots RSL (2019)-Super Record 12
Cervelo S1 (2010)-Super Record 12
Kestrel RT700 (2008)-Dura Ace 9000
Mosaic GT-1 (2020)-SRAM Red viewtopic.php?f=10&t=174523
- Contact:
Just wanted to pop in to say that if anyone is battling road Boost front hub options (or even MTB Boost as seen on some gravel bikes) let me know. Fork and hub conversions to other standards have become my ‘thing’ lately. A 12x110 (or 15x110) fork can easily use 12x100, 15x100, or 15x110 hubs with my kits.
- andreszucs
- in the industry
Don’t care about aero, but how about all the rest above plus 15 speed?satanas wrote: As for "most advanced" that depends on what matters to you - aero, suspension, tyre clearance, weight, something else???
Here is my goal specs:
-Full suspension, with lock
-34mm tires, for fast road riding
-15 speed 1xby, small steps on road, high range for mountains
-Under 19 pounds. Good climber
My stuff on sale https://www.ebay.com/sch/andreszucs/m.h ... pg=&_from=
I'd go for the following specs:
- Great looks and paint/colour schemes.
- Electronic gear shifting with large range and close gearing. This means in practise 11 or 12 speed and 3x as low gearing needs to be much much lower than standard gravel gearing nowadays. I don't have pro W/kg and I also like to ride on steep hill and mountain roads.
- All aero because there will be plenty of riding at reasonably high speeds.
- Tool space inside the frame.
- Possibility for wide tyres, upto 42 mm.
- Full internal cable routing.
- Lighter than boat anchor, below 9 kg.
- No need for specific bikepacking attachments or fenders.
All other requirements can be fulfilled by several modern gravel bikes except for the gearing. I think current gravel gearing is designed for competitive riders and is currently not very well suited for recreational cyclists.
- andreszucs
- in the industry
plrww wrote: - Electronic gear shifting with large range and close gearing. This means in practise 11 or 12 speed and 3x as low gearing needs to be much much lower than standard gravel
At least from my personal experience, 1x proved to be more reliable than 2x or 3x, also lighter. As for Pro vs Recreational riders, using 1x by it would be a simple adjustment; Pro’s would use a slightly bigger chainring. I think the perfect cassette would be a 15sp 9-46 or 10-50.
Whilst I've nothing against more rear cogs, IMHO 15 won't be happening any time soon. There are only a few ways to fit more cogs in:
1. Make them thinner: There has to be a limit before the teeth either fold up or shear off; Ekar must be getting close to it
2. Increase the rear spacing: However, one gear + one spacer ~4mm, so to add two gears on top of Ekar = 8mm more spacing on the RHS or 16mm total = 158mm; SuperBoost is 157mm. Making the chainstays wider is likely to cause ankle clearance issues
3. Make the big cogs bigger and cantilever them over the spokes to get derailleur-to-spoke clearance. At some point though the cog can't get bigger without causing derailleur cage-to-ground clearance problems
Then there's the problem of increased wear and reduced drivetrain efficiency with the greater chain deflection, chain-to-tyre clearance, etc, etc.
I can totally see 13 speed MTB cassettes as these already go up to 52T so can sit a fair way inboard. As well as Rotor there are Chinese manufacturers making them (11-50/52). Presumably SRAM and Shimano will follow suit eventually.
Bingo!tarmackev wrote:Giant Revolt..... Advanced
- andreszucs
- in the industry
14sp is already possible I know a guy that added the extra cog behind the Ekar 9-36 (wireless shifting with an external Mech-to-Wireless adapter). I want to experiment and added two and see if works.satanas wrote:Whilst I've nothing against more rear cogs, IMHO 15 won't be happening any time soon. There are only a few ways to fit more cogs in:
Another word of optimism: Sram FlatTop 12sp chain is 5mm wide and works with the Ekar cassette (I’m using it), it actually works shifting 14sp. The Ekar chain is 4.9mm, that means the Ekar cassette could have 0.1 x 12 narrower spacing and still work, opening 1.2mm more space to add that 15th cog. All that with non boost hubs.
Interesting! It hadn't occurred to me to use something like the Archer shifter to add more cogs:
https://archercomponents.com/
^ Might be ideal for "mad scientist" type experiments. Fabricating suitable cassettes might be more of a challenge unless one has machining expertise and suitable facilities to hand.
For my use (more touring oriented, with very steep loaded off-road climbs) the Ingrid 11-44x12 cassette plus TA's 44x28 GRX pattern rings might be one answer, and it seems Jtek do a Shiftmate that translates between 12 speed Ergopower shifters and Shimano 2x12 MTB rear derailleurs. That would give ~629% range with suitably high and low gears.
Most advanced? Ask John Tomac 91 Raleigh
- short travel suspension,
- crazy aero,mean stop the marginal BS gains, they went full blast with a Tioga disc wheel
- carbon front triangle and Ti rear one.
To me gravel has already lost the simplicity it initially had and marketing teams will continue turning it to 90s MTB
Both John Tomac and Lance Armstrong used rear STI index shifters + front friction shifter - I like this too.
Armstrong used frame mounted friction shifter, Tomac used barend friction shifter.
With front friction shifter and modern hydro STI you can still run 3x13 mechanical rear or 3x12 electronic rear.
Front friction shifter also acts as backup option when electronics/battery or STI mechanism stops working.
- wheelsONfire
I would probably lean towards
https://www.cannondale.com/en/bikes/roa ... on-lefty-1
Bikes:
Open *UP* (2016.04.14)
- andreszucs
- in the industry
10kg bikewheelsONfire wrote:I would probably lean towards
- wheelsONfire
Ofcourse a frameset with dual suspension carry more weight. The question wasn't for the most light gravel bike.andreszucs wrote: ↑Sun Jun 26, 2022 12:30 am10kg bikewheelsONfire wrote:I would probably lean towards
It won't help with comfort if the bike is lighter.
Bikes:
