Fast, light, carbon frames with bento-box mounts and 3x bottle cage mounts?
sib
by sib
I'm looking for a fast, light, carbon frame with a bento-box mount on the top tube and 3x bottle cage mounts.
The Factor LS and Cervelo Aspero-5 fulfill these requirements - are there any others out there?
Thanks in advance!
jemima
by jemima
Winspace G2 / Light Bicycle Journey.
Curve Grovel ti.
markdjr
by markdjr
Open UP or UPPER
sib
by sib
@markdjr
Open added to the list!
@jemima
I'd never seen these frames before - thank you!
I should have specified:
I'm looking for 2x bottle cage mounts in the normal positions, and 1x bottle cage mount on the underside of the downtube.
If I can forego the bento-box mounts on the top-tube, how much does this open things up?
I know this brings the Specialized Crux into the picture..
sib
by sib
Adding the Lauf Seigla and Anywhere to the list
sib
by sib
Also Trek Checkpoint and Scott Addict Gravel
tenja
by tenja
Salsa warbird
spartacus
by spartacus
checkpoint
expatscot
by expatscot
Definitely the OPEN UPPER./ UP. (I'm just trying to find the perfect bento box for mine)
Look 695 aerolight eTap 11
Boardman TTE eTap 11
Brompton S2 LX ti custom
Trek 5500 1994 Sram Red 10
Boardman CXR9.8 eTap 11
Open UPPER - DA 9270
Ridley x-fire Sram Red 10
and lots of non- WW others.
KonaSS
by KonaSS
Not sure about weight, but Felt Breed Carbon should tick the other boxes.
stalkersk
by stalkersk
Ridley Kanzo Fast has 3 bottle mounts.
sib
by sib
Thanks for the replies.
Here's the list so far:
Factor LS
Cervelo Aspero 5
Ridley Kanzo Fast
Open UP/UPPER
Trek Checkpoint
Scott Addict Gravel
Salsa Warbird
Lauf Seigla/Anywhere
sib
by sib
@expatscott
How are you enjoying your UPPER?
sib
by sib
@KonaSS
From the Felt website, it looks like the Breed Carbon doesn't have Bento Box mounts?
Can't see a clear pic of the top tube..
sib
by sib
Ventum GS1 also
