Hi I'm 182cm and can get a frameset of 52cm
I've seen the top tube is quite long and therefore consider even this small size, what do you think?
Trek checkpoint 2022 framesize
What is your saddle height? Trek list the max in the 52cm SLR to the rails at 70.5cm. That is with the long mast cap.
Stop sizing this like a traditional road bike. As jemima mentioned, the long top tube/reach is intended to be run with a shorter stem (on trend with gravel bikes gravitating toward mtb geometry). There's almost no way in hell you should be riding a 52cm, unless you've got some really unusual body proportions. Along with the seat mast being possibly not long enough, I'd imagine stack would be quite short for you too.
