by PoorCyclist on Sat May 07, 2022 9:35 pm
Here is an update, I removed the GRX crank, installed SRAM GXP crank with wolftooth 1x ring. 1x GRX derailleur.
The chain moved towards the frame (measured at the seattube) by a little over 3mm.
There is NO tire to chain clearance issue with 700 x 40c tires which is the biggest tire I can fit. 650b could fit a wider tire I suppose, not sure if I agree with Shimano making their cranks wider to address an issue 95% of bikes does not have. I know SRAM put out a wide crank and wide FD, but at least you have a choice.
No problem in any cog. I can absolutely backpedal in any cogs now. Since I moved the chainline inwards, the interaction with the smallest cogs was a concern. The result is only the 2 smallest 2 cogs make a little "tick" when back pedalling to re-align itself.
Riding here is very steep so chain being straighter in the biggest cogs makes it more effecient in my use case.
Why is backpedalling a big deal to me? Well, I need to pick up the pedal with my shoe from the bottom about 1/4 turn to start riding off. When it's in the bigger cog if the chain drops to one cog lower, the derailleur is still in the big cog, you jam the chain, you do not want to force it with your leg because it will bend stuff. When you need a take a stop riding up hill and try to restart, the chain drop off, and since you cannot force it, you have to get off the bike, lift it, spin the bike and remount again. That was the most frustrating thing with this new 1x system.
My shoe rub is gone and I was able to raise my saddle by 15mm, before, due to the wide q-factor I was forced to lower my saddle because otherwise my legs are like this / \ , with the lower saddle it's mostly quads action which can burn me out easily. Now the leg alignment to pedals are very natural like other road bikes.
The 200g weight loss is a very nice bonus as well.
