RDY wrote: ↑Thu Jan 26, 2023 4:49 pmThe DA/Long B screw works, but not very well at all. I am pretty sure it would work better/well with the Wolftooth, but I haven't tried it yet.markdjr wrote: ↑Thu Jan 26, 2023 6:11 amI've run it on 2 bikes, Shimano DA 12spd with long b screw as well as SRAM Red AXS w/ Wolftooth or AXS XPLR. While it is not listed as 2x compatible, AXS XPLR will work with front derailleur in my experience.You just swapped to a longer B-screw bolt and it worked on the DA12s? Pics of both setups?RDY wrote:
New GRX this year?
markdjr wrote: ↑Mon Jan 30, 2023 5:48 pmThanks. Though I was hoping to see the the FD and RD. Are those Cava Race tires?RDY wrote: ↑Thu Jan 26, 2023 4:49 pmThe DA/Long B screw works, but not very well at all. I am pretty sure it would work better/well with the Wolftooth, but I haven't tried it yet.markdjr wrote: ↑Thu Jan 26, 2023 6:11 amI've run it on 2 bikes, Shimano DA 12spd with long b screw as well as SRAM Red AXS w/ Wolftooth or AXS XPLR. While it is not listed as 2x compatible, AXS XPLR will work with front derailleur in my experience.You just swapped to a longer B-screw bolt and it worked on the DA12s? Pics of both setups?RDY wrote:
Do you mean better with the WolfTooth long screw? Or one of their other products? You are running third party cages though, which I'd guess is the key to this working. What are the official capacities of the DA / Red XPLR CS OSPW cages?
RDY wrote: ↑Mon Jan 30, 2023 6:42 pmI meant I think Dura Ace and Wolftooth Roadlink would work better than Dura Ace and long b screw. I do think the cages make a difference in it working or not, but I think you could likely do this with the stock cages as well. I don't know what the official capacity is but I am WAY outside it. To be clear, the picture above is standard RED not XPLR, the RED/Wolftooth seemed to work better than RED XPLR based on my quick test in the stand.markdjr wrote: ↑Mon Jan 30, 2023 5:48 pmThanks. Though I was hoping to see the the FD and RD. Are those Cava Race tires?RDY wrote: ↑Thu Jan 26, 2023 4:49 pmThe DA/Long B screw works, but not very well at all. I am pretty sure it would work better/well with the Wolftooth, but I haven't tried it yet.markdjr wrote: ↑Thu Jan 26, 2023 6:11 am
Does anyone have good advice on where to buy full GRX RX815 groupset in (or to) the US? Most retailers seem to list all the components individually which makes comparing full costs a chore. I'll do it one part at a time if I have to, but it would be nice to be able to compare a full package.
- ultimobici
- in the industry
- Contact:
Shimano GRX Di2 has never been available as a groupset. Some dealers used to offer a package but with supply issues that is harder and harder to manage. The variations between 1X & 2x make it a pain because you always end up with the stuff no one wants! Just look for the parts individually.we51 wrote: ↑Thu Feb 02, 2023 6:12 amDoes anyone have good advice on where to buy full GRX RX815 groupset in (or to) the US? Most retailers seem to list all the components individually which makes comparing full costs a chore. I'll do it one part at a time if I have to, but it would be nice to be able to compare a full package.
Hello, can anyone tell me if it's possible to install a Ceramic Speed OSWP-X cage on the Shimano rear derailleur GRX-817 with 1 x front ring and 11-40 cassette?
Would it work?
CeramicSpeed said that isn't possible, max 34 cogs at the back, but maybe despite they say that somebody tried it.........
Let me know, thanks in advance,
Andrea
Would it work?
Andrea
new Shimano patent related to cassettes/freehubs
In it the 3 types of freehubs are represented (Microspline, HG+ and HG) Will it have something to do with the next GRX?
https://image-ppubs.uspto.gov/dirsearch ... f/11578761
- ultimobici
- in the industry
- Contact:
So, no Microspline Road?Ritxis wrote: ↑Tue Feb 14, 2023 3:06 pmnew Shimano patent related to cassettes/freehubs
I think I tried to fit an OSPW to an rx817 and it did not work out. I think you can run a GRX815 and an 11-40 cassette, even though its stated capacity is 34t.SQUICCHI wrote: ↑Mon Feb 13, 2023 8:06 pmHello, can anyone tell me if it's possible to install a Ceramic Speed OSWP-X cage on the Shimano rear derailleur GRX-817 with 1 x front ring and 11-40 cassette?
Would it work?
Andrea
The new Shimano CUES family to replace all mechanical, flat and drop bar, from 9 to 11 speed?
GRX as a12 speed only range? A mechanical and a Di2 option?
read more about the CUES, which seems to only be related to Mtb/urban systems below the Deore...if there are CUES in road groups I suppose they would be below the TiagraCarlosFerreiro wrote: ↑Tue Feb 28, 2023 5:57 pmThe new Shimano CUES family to replace all mechanical, flat and drop bar, from 9 to 11 speed?
The articles so far suggest CUES to replace Deore down and Tiagra down with a common ecosystem across flat and dropbar for 9,10 and 11 speed options, all sharing the same mech geo, cassette sprocket spacing and cable pull ratios, all using an 11sp spec chain. No dropbar stuff shown yet though.
Last edited by CarlosFerreiro on Tue Mar 14, 2023 12:21 pm, edited 1 time in total.
There's been nothing substantial at all about Cues for road - only rumours about rumours. No need to panic about it yet, but if it happens panicking will be eminently reasonable IMHO. Cues might be good for OEMS, but a nightmare for everyone else until all the pre-Cues stuff is worn out or has been abandoned.
The only part that's really missing for 12 speed GRX is a clutched rear derailleur; all the other bits are mostly present in other groups. They might not have the same cosmetics, but that shouldn't matter much...
