Gravel tyres have been aero tested
It's interesting to see this, but would be even more interesting if they combined it with rolling resistance. I'm curious if there's a point where they cancel each other out.
Also, these numbers aren't as high as forum randos lead me to believe.
Doesn't seem to be a too relevant factor for consideration really.
With 2.0W being the difference between the knobbiest tire in the test vs an almost slick, that is also 2mm narrower.
Rolling Resistance, control and traction should still be the highest priorities imho.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
This was my take away from the testing. I thought the gap could be much bigger.FlatlandClimber wrote: ↑Sat Jan 22, 2022 12:38 pmDoesn't seem to be a too relevant factor for consideration really.
I think all this aero crap is just that...CRAP! I bet if you bought all the stuff, from helmets, to pedals, to tires, to rims, to whatever they got that make these watts savings, and added up all the watts they promise you could be hovering around 50 watts and probably more but I'm trying to be conservative, which would make you really fast, which is why it's all a marketing hype to get you to buy their crap because cyclists are gullible, just like the previous big corporate hobby, golf that had their huge promises of improving your score if you buy this and that stuff, and none of that stuff worked in golf either, nor will it with cycling, but will reduce weight by making your pocketbook lighter.
Raced tt's for a number of years over a set course.froze wrote:I think all this aero crap is just that...CRAP! I bet if you bought all the stuff, from helmets, to pedals, to tires, to rims, to whatever they got that make these watts savings, and added up all the watts they promise you could be hovering around 50 watts and probably more but I'm trying to be conservative, which would make you really fast, which is why it's all a marketing hype to get you to buy their crap because cyclists are gullible, just like the previous big corporate hobby, golf that had their huge promises of improving your score if you buy this and that stuff, and none of that stuff worked in golf either, nor will it with cycling, but will reduce weight by making your pocketbook lighter.
It absolutely makes a difference.
I am now an old bastard at 53yo.
I run an specialized evade helmet and 50mm wheels on the roadie in fast bunch rides with blokes half my age. It is helping me hang on.
Have to say I am more of an aero weenie than a weight one.
LOL!!! A helmet did all of that? LOL~!! I think the wheels did all of what you felt, the helmet didn't do squat, ask me how I know.warthog101 wrote: ↑Sun Jan 23, 2022 12:13 amRaced tt's for a number of years over a set course.froze wrote:I think all this aero crap is just that...CRAP! I bet if you bought all the stuff, from helmets, to pedals, to tires, to rims, to whatever they got that make these watts savings, and added up all the watts they promise you could be hovering around 50 watts and probably more but I'm trying to be conservative, which would make you really fast, which is why it's all a marketing hype to get you to buy their crap because cyclists are gullible, just like the previous big corporate hobby, golf that had their huge promises of improving your score if you buy this and that stuff, and none of that stuff worked in golf either, nor will it with cycling, but will reduce weight by making your pocketbook lighter.
When I was talking about Aero BS, I was referring to the small stuff, not a bike frame or wheels. I should have clarified that in my first statement. I'm talking about the goofy stuff like pedals, shoes, tires, helmets, saddles, that sort of small stuff.
How do you know?froze wrote:LOL!!! A helmet did all of that? LOL~!! I think the wheels did all of what you felt, the helmet didn't do squat, ask me how I know.warthog101 wrote: ↑Sun Jan 23, 2022 12:13 amRaced tt's for a number of years over a set course.froze wrote:I think all this aero crap is just that...CRAP! I bet if you bought all the stuff, from helmets, to pedals, to tires, to rims, to whatever they got that make these watts savings, and added up all the watts they promise you could be hovering around 50 watts and probably more but I'm trying to be conservative, which would make you really fast, which is why it's all a marketing hype to get you to buy their crap because cyclists are gullible, just like the previous big corporate hobby, golf that had their huge promises of improving your score if you buy this and that stuff, and none of that stuff worked in golf either, nor will it with cycling, but will reduce weight by making your pocketbook lighter.
https://road.cc/content/feature/should- ... met-202070
https://www.bicycling.com/skills-tips/a ... n-cycling/
https://www.active.com/cycling/articles ... els-880495
At what point did I attribute all of anything to a helmet?
A helmet is part of the package, as are wheels and body position.
Of course body position is most important.
However once you have that sorted, why not a helmet and wheels?
I needed a new helmet so why not aero.
I know from multiple timed results over the same course that wheels are also effective.
This is all on a roadie however.
I do plan on some better wheels for the gravelly also.
2 sets of wheels when I travel. One with gravel tyres and road tyres on the faster wheels so only one bike needs to be taken and can be used on road or gravel.
Road tyres ime are significantly faster.
I'd call this a textbook manifestation of the "no true Scotsman" fallacy. If nothing else, it's moving the goalposts.
The sum of the small things makes a relevant difference, especially at high speeds. Gravel however is not high speeds, really.
Posted unironically in the weight weenie forum.froze wrote: ↑Sat Jan 22, 2022 11:30 pmI think all this aero crap is just that...CRAP! I bet if you bought all the stuff, from helmets, to pedals, to tires, to rims, to whatever they got that make these watts savings, and added up all the watts they promise you could be hovering around 50 watts and probably more but I'm trying to be conservative, which would make you really fast, which is why it's all a marketing hype to get you to buy their crap because cyclists are gullible, just like the previous big corporate hobby, golf that had their huge promises of improving your score if you buy this and that stuff, and none of that stuff worked in golf either, nor will it with cycling, but will reduce weight by making your pocketbook lighter.
