1-1.5kg gravel frameset with 68mm bottom bracket
I want to build a lightweight electric gravel bike with a revolutionary mid-drive motor of my own design. Think of about 14kg including battery and a Rohloff gear hub. My motor can be mounted on any frame just like the TSDZ2.
For this, I’m looking for the lightest frameset, 1-1.5kg. It is important that the bottom bracket must be 68mm wide, preferably PF30. (86mm bottom brackets will make the Q factor too large).
A gravel frame is necessary due to the wide tires.
An aluminum frameset with carbon fork is my preference.
The disadvantage of carbon frames is that you can’t use a Pletscher rear kickstand on it (without ugly mounting brackets). I use the ebike for my solar-powered bike, the Maxun One, and therefore I absolutely need a kickstand.
An aluminum frame is also more tolerant of the mechanical stress from the mid-drive motor and the mounting of the solar panels.
https://www.avdweb.nl/solar-bike/solarb ... solar-bike
The frame must also have rear rack mounting points. But note that my luggage carrier weighs 120 gram. I never have more than 1kg of luggage, not even for multi-day trips.
So these are the requirements:
Aluminum or carbon gravel-frameset.
Weight 1-1.5kg
68mm bottom bracket
Rear rack mounting points
Who can help me?
Weight 1-1.5kg
68mm bottom bracket
Who can help me?
I use a PF30 on my 696 with a Rotor BB. It works really nicely and this BB a has seen over 7500 wet UK/Irish and Swiss miles.
Thank you for your advice.
The weight is 1660g, this is not soo lightweight.
But the frame may therefore be stronger than lighter frames?
I can't use BSA-68mm because my mid drive motor needs a pressfit botom bracket system, no screw thread.
So it can be ordered with PF30?Steve Curtis wrote: ↑Fri Jan 21, 2022 9:38 amI use a PF30 on my 696 with a Rotor BB. It works really nicely and this BB a has seen over 7500 wet UK/Irish and Swiss miles.
Best to search through the available bike brands and their Alu frames for you to ascertain which are the lightest. Perhaps a Cannondale Caad or something like that.
If you could present your findings then I'm sure many people here would be able to share some feedback if they've had those frames before. My old Wilier Alu frame was about 1.5kg but that was a good decade old.
I would second the Carbonda recommendation - I think it's workable, it's affordable, and it's a very popular frame so any issues should have been ironed out by now.
(I know nothing about kickstands, but if you want aftermarket accessories, it really helps to have something popular)
It should have ended here. Take it somewhere else; people come here to read about bike stuff, not pages of pointless bickering.
Sent from my computer using an internet browser.
- robbosmans
- Moderator
- Contact:
Removed the off-topic "debate", here is an article explaining it, now let's keep this on topic
https://wheelsmfg.com/blog/three-common ... tions.html
Except that it fails to meet the one critical requirement for the build of having a 68mm bearing width. Despite Steve Curtis's bizarre misunderstandings you cannot make a BSA frame into a PF30.
The T47 version sold by Bombtrack could work with an internal instead of external BB.
