Light 28mm tire for touring/road
charirider
by charirider
As topic name states, I need a light touring/road/light gravel tyre, in size no more than 28mm, maybe 30mm max with thread pattern is as close to slick as possible, preferably lightweight.
At the moment, I ride 2018 SS EVO rim brake version, which has 28-30mm tire clearance; wheelset is custom built: DT 240 hubs, RR440 rims, 28/28 Competition spokes, tires are Conti GP5000 25mm (measuring around 26mm on current rims).
Ride quality is ok, but a little but harsh, want wider tires to run lower pressure for more compliance, as I ride long distances and now mainly do touring on this bike, and here in Japan, countryside roads aren't always great.
I am considering:
1) Just switch to 28mm GP5000S and go tubeless
2) Panaracer GK slick, but I don't like reliability, they cut really easily
3) Rene Herse Chinook Pass Extralite can someone comment on their puncture resistance?
4) Other variants?
Looking forward to your suggestions!
2018 Cannondale SuperSix EVO 2 rim size 56 (raw stripped) 6.8kg
2014 Bridgestone Anchor CX6 Equipe size 55 (cyclocross) 9.6kg
pdlpsher1
by pdlpsher1
Conti now has a new 5000S TR tubeless tire in 30mm. If 30mm is too wide for your frame honestly you need a new frame with disk brakes, one that can fit a proper 32-40mm for touring/gravel.
jemima
by jemima
IRC Formula Pro Tubeless Light comes in a 28gm.
Curve Grovel ti.
charirider
by charirider
pdlpsher1 wrote:
Sat Dec 04, 2021 5:41 am
If it's right on 30mm, it will fit. I have successfully fitted 28mm Panaracer GK SS, on reynolds ar x rims measuring 29mm and it was some 5mm space left. I think it's due to my frame size (56cm)
DA9100 calipers should clear 30mm prerry easily also and, on a current rims, it will be a bit undersized I think:
pdlpsher1
by pdlpsher1
Conti 5000S TR is true to size when mounted to a rim with an internal width of around 19mm. If your rim is say, 17mm, then a 30mm tire will come in at around 29mm. I have mounted a 32mm tire onto a 17mm rim and it came out to 31mm.
charirider
by charirider
pdlpsher1 wrote:
Sat Dec 04, 2021 8:11 am
Thanks for the information! I will try 5000TR then! Really like GP5000 performance and durability.
Miller
by Miller
I've been using a pair of GP5kTL 28mm for a couple of years, they have been trouble-free and tough, I've done stretches of light off-road on them. The new GP5KS TR is supposedly a lighter tyre so I wonder if it has given up some toughness in favour of speed.
nickf
by nickf
I have had great luck with the Bontrager R3 in 28c. They ride exceptionally well and have proven to be durable so far. I have the non tubeless version.
nachetetm
by nachetetm
Hutchinson Fusion (get punctures that seal easily past the 3000 km mark) or Vector (more rugged) They run true to size and are as good to install tubeless as any.
Enviado desde mi RMX2144 mediante Tapatalk
froze
by froze
The most comfortable riding tires will ALWAYS BE the ones with the most TPI combined with a wider tire, however tires with high TPI are also more prone to flats, unless it's a Conti 5000 which while it does have a high TPI they also put in a flat belt which in turn made the tire stiff feeling.
I would probably recommend the Pirelli PZero Velo, these have been reviewed by many riders who say they are most comfortable riding tires outside Vittoria tires, and the Pirelli's do come in a 28.
Remember too that if you switch to a wider tire, you don't use the same amount of PSI as you did with 23's, you use less PSI depending on your body and bike weight combined. Another good tire is the Vittoria Rubino Pro III tire.
spartacus
by spartacus
This will probably be unpopular but maybe just use gatorskins.
basilic
by basilic
People's preferences wrt tires vary a lot, and tires are cheap enough that you can experiment. If it was me I'd go with RH/compass for their superb feel, and see if they last enough for your conditions. The standard line is great, much better than gravelkings. The EL have somewhat fragile sidewalls, but the center rubber is fine. I just retired a rear 28mm compass EL after 4-5K km without a flat, it wore thin, but that's not the rule.
BenSiskri
by BenSiskri
A shout out for Vittoria Corsa Control 30mm; fitted them last August (2020) on my 'winter hack' Domane ALR rim brake bike; and run tubeless, they were fabulous. Just put more sealant in than recommended. I ride on some pretty rubbish road surfaces, and can't find any fault with them. Saying that, they have gone up in price since I purchased them.....
Trek Crockett 4
Giant TCR Advanced 3
takolino
by takolino
No complaints with Rene Herse but with limited miles. I have extra light versions of Chinook Pass and Stampede pass, both have held up, rolls and corners well on pavement and with occasional gravel use with the Stampede pass. I've rode each probably no more than 500 mi. I rode GP5000 and before that, GP4000 and I noticed a slight rolling resistance improvement between GP4k and 5k but not much difference when I switched to RH. This could be only perception though since I also went from 25c-28c-32c. For 28c, I'd probably stick with GP5k.
rjich
by rjich
I enjoy the feeling of the Vittoria tires. Corsas feel nice at 28mm measured nearer 29. I'd purchase the control ones if I needed more puncture resistance, but haven't had an issue with the Corsa over past 6 month. Gp5000 feel stronger in hand.
