Power2Max double to single chainring?
the_marsbar
by the_marsbar
I bought a P2M NG spider (for Rotor 3D+) for a double chainring setup.
I'd like to explore the options for running a single chainring on the crankset with the P2M spider.
Anyone with experience with chainrings that would work well? Would it need to mounted on the "inside" to get a proper chain line?
The bike is a Focus Mares CX.
erik$
by erik$
I have used narrow-wide FSA megatooth chainrings on my p2m Type S, without issues. The ring has an offset and is mounted on the outer position.
the_marsbar
by the_marsbar
Cool. Thanks. Do you know of other chainrings that could also be used?
erik$
by erik$
I think the Praxis wavetech is also an option. There are plenty of narrow-wide rings for 110 mm but not a lot of them have offset. The need for offset depends on the chainline of the crankset, gear selection and personal preference.
