WILL SRAM AXS XPLR will work with 10-33 cassette???
Because the pulleys getting to far from the biggest cog or too close to the smallest if adjusted "correct". Their made a certain raise to be able to work great both with a big biggest cog and small smallest.
I haven't tried the XPLR but regular shortcage with a Garbaruk cage doesn't like the 10-28 so well, bad gearing on the small cogs.
/jonas l
http://instagram.com/jonaslundb
- Moderator
Could I run the 10-46 XPLR with an eagle RD?
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
Bertha- TT 9.8kg
I believe that the AXS road/XPLR use different cassette spacing to the Eagle (I think this is why Ratio make different ratchets for their Eagle and Wide conversions too) so the XPLR cassette won't play nice woith the Eagle mech. But, a 10-45t Shimano cassette should work if that's the sort of spread you're after.
- Moderator
Yeah that would work! Just when I shove the CX wheels in want less range
Bertha- TT 9.8kg
Bertha- TT 9.8kg
Does anybody has any real life experience yet?
I finally sourced a 10-33 and it works well enough with the Force AXS XPLR rear derailleur.
To those curious for usage specific to cyclocross, why not use the 11 speed etap derailleur and 11 speed cassettes for cx? The new AXS shifters work with the older 11 speed etap and it's going to be a lighter and cheaper setup.
Sent from my Pixel 3 XL using Tapatalk
https://cyclingtips.com/2021/11/sram-in ... tap-users/
That's good, though a little shitty they're feature gating Rival AXS out of it.NLC86 wrote: ↑Tue Nov 16, 2021 9:00 amhttps://cyclingtips.com/2021/11/sram-in ... tap-users/
You know what would be really nice ... if AXS RDs worked with 11 speed cassettes, or do they maybe, and it's just not a publicised feature?
