Well, it's not a marketing claim, it's simple geometry. With an asymmetric rim the spoke nipple line is more centrally placed between the hub flanges than with a symmetric rim. That in turn means there's less of a disparity between left/right spoke tensions. This is unequivocally a good thing.simbikotic wrote: ↑Wed Dec 08, 2021 7:12 pmYep. That's the marketing claims at least! Who knows how important that is.
Farsports gravel rims
While I don't disagree, the best way to get near equal spoke tension is to build with 2:1 triplet lacing, and it's grown evermore unpopular, finding a triplet hub is near impossible nowadays. My next wheelset might be the first non-triplet rear I've had in the past 10 years (excluding my singlespeed rear which had symmetric hub flanges).Miller wrote: ↑Wed Dec 08, 2021 9:30 pmWell, it's not a marketing claim, it's simple geometry. With an asymmetric rim the spoke nipple line is more centrally placed between the hub flanges than with a symmetric rim. That in turn means there's less of a disparity between left/right spoke tensions. This is unequivocally a good thing.simbikotic wrote: ↑Wed Dec 08, 2021 7:12 pmYep. That's the marketing claims at least! Who knows how important that is.
Maybe the stiffness of current rims makes spokes unload less than in the past? Or that everyone is overbuilding wheels for their weight.
I own one set of these rims, the asymmetric 36/32 hooked ones, and have built them 28+28 on a ztto hubset. It was a tryout for me to build a carbon wheelset, and I use it with 32mm gp5000 tyres as road wheels for my gravel bike. I like them so much I've ordered a new pair of rims to build onto an erase hubset to support my gravel tyres too (the fact the ztto hub is 6 bolt makes it very easy to shim the discs to make swaps really easy).
System weight is 95kg ish so prefer to go 28h front and rear. The asymmetric rim balances the tension a bit, it does not equalise left and right side completely.
Question on Farsports wheels regarding hooked vs. hookless.
Are there some tires that will not work with the hookless rims?
Also- I know they give pressure ratings for all there rims, but should I expect that I need to run lower pressure if going hookless? Especially if I am using a road-ish type tire?
All modern Tubeless tires will work with hookless provided they are kept at low pressures. One of the caveats about running a super wide hookless rims with gravel sized tires is bead retention suffers. Hard side loading has a tendency to pull the bead up and off the rim. That and having the sidewall/rim edge as the widest part on a bike that gets ridden offreoad leads to rims getting buggered and sidewalls more exposed to puncture.
I am running their hookless gravel rims and have had no issues with many tyres. As had been said low pressures are the key. I even ran GP 5000tl's on them with great success.boots2000 wrote: ↑Fri Dec 10, 2021 5:51 pmQuestion on Farsports wheels regarding hooked vs. hookless.
- saldegracia
same here, 43mm Gravelking SK on my 26mm internal Farsports rims (hookless). Works perfectly but the tires come out a little wider, around 46mm in my case. As you say, looke like a perfect fit for me, tire is nice and wide, no bulging, I can easily run 2 bars of pressure and have not had a single puncture with this wheel tire combination in more than 5000km, probably 80% of which offroad...tritiltheend wrote: ↑Thu Oct 28, 2021 6:57 pmI'm running 40-45mm tires on a set of Farsports 26mm internal width rims with no problems whatsoever. I'd rate those widths as a good fit for that size tire, not an edge case.
Canyon Aeroad, Votec VRC, Fuji Jari Carbon, Sensa Fermo SL, Principia R700, Cannondale Bad Boy Ultra, Ciöcc Singlespeed
Those sound amazing, anyway to post a pic?
I've been thinking of the same rim/wheel set up for some gravel.
