2022 Giant Revolt Advanced
safd009
by safd009
samarskyrider wrote:
Sun Sep 22, 2024 2:52 pm
Anyone tried 30mm ID rims on Revolt?
Yes, not a problem. Sworks Pathfiner 42mm went to 47mm.
spinny13
by spinny13
Tue Sep 17, 2024 4:09 pm
Finally, new tires arrived - Schwalbe Thunder Burt 29x2.1" The look is now complete
Nice bike. Can you give me info about your gearing? I am mostly interested in the crankset: As I see it is a quark road crank with quark powermeter and a 46 tooth chainring? No issues with chainring clearance? What do you think, would the thunder burt fit with 2X crankset (50x34) - gravel or road one? If not what about a 45 or 47 mm tyre? Thx.
samarskyrider
by samarskyrider
Thanks!
It's a 110BCD Quarq spider with extra 4mm chainring bolt spacers to clear 46T. I haven't considered 2X for gravel, so I'm not sure if it will clear double crankset.
However, flip chip moves rear axle 5mm away from BB, so it may help with FD clearance. Given all that, I'd stay with 45-47mm tires to be on a safe side with 2X
fezi
by fezi
I've fit a 50mm Conti Terra with a 2x Sram. Was a wide crankset (47.5mm chainline) and had room for a 3mm allen key to slide between the front mech in the forward position of the flip chip. There would probably be more clearance for a shimano mech.
stoney
by stoney
fezi wrote:
Wed Oct 16, 2024 10:07 am
Did the Conti Terra actually measure 50mm installed on the rim? Some tires state they are 50mm but actually measure less or more depending on the rim.
fezi
by fezi
Was bang on 50mm on my calipers on a 25mm internal rim.
joebusby
by joebusby
Anyone heard when the integrated new frameset will get released?
warthog101
by warthog101
I like the tyres.
How much clearance is there at the rear?
I am wondering if they may fit on my 2021 Revolt? The front yes, but the rear is tighter.
edit; disregard sorry. I read your post a few before mine.
samarskyrider
by samarskyrider
joebusby wrote:Anyone heard when the integrated new frameset will get released?
It's been released couple of months back
wezep
by wezep
Does anyone weighed the new 2025 Revolt Advanced Pro frameset?
joebusby
by joebusby
Fri Oct 18, 2024 7:17 pm
You've misunderstood me. I was asking when we can buy the frame - not when we might see it in reviews.
Kurt1980
by Kurt1980
Has anyone personally installed a road size crankset on their pre 2025 Revolt? I'm talking at least 50/34 (37 if SRAM) or maybe larger crankset. I've seen the photo of Trekky, thanks for that link.
I'm using my Revolt for road duty at current, it's surprisingly good for solo rides at 48/31x 11-34, but in fast group rides I'm sometimes spinning out. I am using a SRAM wide Rival AXS FD.
TIA!
joebusby
by joebusby
joebusby wrote:
Tue Oct 22, 2024 6:03 pm
FWIW I asked my giant dealer and the answer on the integrated 2025 revolt is may 25
wltz
by wltz
Kurt1980 wrote:
Mon Nov 18, 2024 10:39 am
TIA!
Running 50/34 on my 2021 Revolt, as it's basically on a permanent winter/turbo bike duty.
Kurt1980
by Kurt1980
wltz wrote:
Tue Nov 19, 2024 11:04 pm
TIA!
Cool, thanks. I take it that's the +2.5mm chainline and that's an all Shimano setup....are you running non Shimano chainrings on a GRX setup? Or normal road crank with BB spacers? Curious how you have this going.
Cheers!
